Old 11-18-2006, 09:45 PM
holeshot87
Exclamation propane heater size
i build a 6'hx4'dx3'w oven. i going to heat it with a propane torpedo heater. what size do i need to get it to 400 degrees. i would like to buy one that i can adjust the btu's.
Old 11-19-2006, 07:05 PM
holeshot87
Cool Re: propane heater size
its hard for me to believe all the people out there building ovens no one can tell the size (btu's) torpedo heater i need.(propane)
Old 11-19-2006, 11:07 PM
krusty2111us is on a distinguished road
Default Re: propane heater size
http://www.heatershop.com/btu_calculator.htm
This calculator should get you in the right direction. It's the first thread link(sticky) when you open the oven building forum. Also the search function on this site works pretty well.
If I input your numbers correctly, it says you need:
good insulation/tight leakage 19,200 btu's
average insulation/average leakage 38,400 btu's
It all depends on your fabrication and building skills as to your leakage rates. I build and fabricate custom things for a living, and I had to work very hard to get slim-to-no leakage, other than the venting I designed into the oven. Start your search for a heater from there. Hope this helps
Old 11-23-2006, 10:22 AM
Aardvark's Avatar
Aardvark
Wink Re: propane heater size
Sent you a P.M. several days ago with an answer....
Hot Shot Powder Coating
Highland Lakes Area of Texas
propane heater holeshot87 Oven Building Forum 7 11-21-2007 10:18 AM
curing with propane heater kchotboat Powder Coating Questions 4 11-09-2007 10:55 AM
advice on oven propane or electric RCC Powder Coating Questions 13 11-26-2006 09:57 PM
powder coating near propane heater? randygrapes218 Powder Coating Questions 3 12-16-2004 09:05 AM
plating and size power? chromo Electroplating Questions 7 01-18-2003 02:52 AM
