+ Reply to Thread
Results 1 to 10 of 10
Thread: oven insulation
  1. #1
    Default oven insulation
    I have been reading this fourm for a few days....very cool!
    anyways im going to build a oven to do my rear end and some other suspension parts. what type of insulation are you guys useing? name?
    product number? manufacture? any help would be cool. it looks like a fiberglass type stuff but im not sure. anyone want to build a laser to draw pictures and cartoons on clouds, moutians etc? email me ive been building lasers most of my life and can tell you the how its done....thanks...rob
    Share with Facebook
  2. #2
    Join Date
    Jun 2006
    Posts
    620
    Default Re: oven insulation
    Just regular Fiberglass insulation is what most people use. It holds up to alot of heat.
    Build lazer's, freakin cool. I want one
    Dan Pesonen
    Forest Grove, BC Canada
    Personal motto:
    Share with Facebook
  3. #3
    Join Date
    Jan 2005
    Location
    Monessen PA USA
    Posts
    174
    I think the best stuff to use is Owens Corning #703 ridge fiberglass it's easy to work with, it stands up by it self. I'm from Pittsburgh I got mine at George V. Hamilton Inc. in Mckees Rocks 412-771-0900 www.hamiltongv.com mine was 2" x 24" x 48" sheets. Cover the hole inside with metal before you fire it up lol lol wow did that stink. Rock wool is good also. And you can cut it with a little hand saw
    Share with Facebook
  4. #4
    Join Date
    Jan 2005
    Location
    Monessen PA USA
    Posts
    174
    Share with Facebook
  5. #5
    Join Date
    Jan 2005
    Location
    Monessen PA USA
    Posts
    174
    Share with Facebook
  6. #6
    I am going to be making a fridge oven I thought I would be doing sooner but **** happens, any way I was wondering why the insulation that is already in the fridge cann't be used if it will be covered with either sheet metal or cement board? and would it be better to make it lying on it's side with the elements on the sides, for more even distribution.
    thanks Rich
    Share with Facebook
  7. #7
    no info, Please I would like to start the fridge this weekend..
    Share with Facebook
  8. #8
    Join Date
    Feb 2006
    Location
    Pickens, SC
    Posts
    156
    I've read in some other posts that the fridge insulation will not take the heat and possibly burn. I'm not sure though. I used mineral wool in mine.
    Share with Facebook
  9. #9
    Here is what I did with my fridge retrofit. I pulled the door off and took off the liner. Then simply exposed the insulation to propane torch. If it burns remove it. If not you should be good to go.
    Ken
    Share with Facebook
  10. #10
    sounds like a good idea. I'll try that tomorrow and post the results.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Cooking up an oven project...
    By dagobert in forum Powder Coating Questions
    Last Post: 06-09-2008, 03:43 PM
  2. Oven problem !!!!!
    By tavo1765 in forum Powder Coating Questions
    Last Post: 10-06-2005, 05:21 PM
  3. Roofing insulation oven?
    By knightda8 in forum Powder Coating Questions
    Last Post: 02-07-2005, 09:48 AM
  4. Rigid Board Insulation for Oven Construction??
    By trsick in forum Powder Coating Questions
    Last Post: 11-17-2004, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
