  #11 (permalink)
Old 11-30-2006, 10:30 PM
joe_bob1999 is on a distinguished road
Default Re: The $20 Motorcycle Rim Powder Coat Oven
Those "space suits" are shiny for a reason...
"Luke...I AM your father!....."
  #12 (permalink)
Old 12-01-2006, 06:44 PM
Originally Posted by joe_bob1999
I'm sure any insulation will help, but the key is the shiny surface of the sheet metal and foil...it really reflects the heat back in. With an infrared thermometer I could measure the surface temp while it was running. Except for where the heat gun was located the external temp would get to 110º to 140º. Actually the biggest issue I had was from contamination in the powder. I made the mistake spraying the first parts in the laundry room and the static charge the parts retain attracted a lot of lint and other stuff floating around the room. Now I use a plastic drop cloth to make a "clean" space to spray right next to where the oven is.
You will not get an accurate temp with a IR gun on alum foil Or any shiny surface for that matter. Different materials have different emissivity ratings. meaning, they give off different IR levels for a respecive temp. Flat black works the best for IR guns. Even different color powders will have different temp readings. Try coat a bunck of test panels different colors, then heat the oven to 200*. see what the gun says. IR guns are good, if your doing the same thing all the time.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 09:15 AM
Two Tone Powder Coat engineerscott Powder Coating Questions 5 03-27-2006 12:44 PM
can I use a gas oven for powder coat corybarta Powder Coating Questions 1 02-10-2005 10:58 PM
powder coat curing in kitchen oven? iceboy Powder Coating Questions 7 01-29-2005 01:57 AM
Laser printer = Powder Coat Printer? tbloss001 Powder Coating Questions 11 08-30-2004 07:08 PM
