does anyone know where or how i can get a thermostat that will work with a torpedo heater.also how to hook it up to shut off and turn the heater back on. also how does the propane stop leaking out where it is shut off. the oven will be running at 400 degrees.
Propane heaters either have the thermostat already or not. Adding one to a unit that doesn't is tricky since you need to stop and start the gas supply. Easiest way to control temp in your situation is via venting and shutting down the heater. You could also add some firebricks inside to act as a thermal mass and absorb the heat while it is firing and radiate it back out when it isn't. Might give you a better way to even the heat out. Good Luck Ken Last edited by Hobweld; 11-27-2006 at 08:48 PM. |
| help with thermostat wiring | jf | Oven Building Forum | 1 | 09-16-2006 07:35 PM |
| Forced air heater thermostat? | wamontgomery | Oven Building Forum | 1 | 07-17-2006 03:09 PM |
| Thermostat location | blackcamaros | Oven Building Forum | 3 | 05-17-2006 02:39 PM |
| thermostat question,newly built oven is alive | gaskincrew | Oven Building Forum | 5 | 05-03-2006 09:09 PM |
| dang thermostat not working ,hellllp | gaskincrew | Oven Building Forum | 1 | 04-28-2006 07:43 PM |
