Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 12-04-2006, 10:17 AM
defed is on a distinguished road
Default using elements of different ratings
i have one oven for parts (still need another). the 2 elements have different wattage ratings....something like 2750w and 3500w. can these be used together (and with a presumably different rated 3rd element) and function correctly? i would presume that at some point inside the oven they came from that they were both used at the same time.
i'm just not sure if the lower rating of one would affect the max output of the other, or vice versa.
thanks
Dave
Old 12-04-2006, 06:22 PM
Default Re: using elements of different ratings
Nope, you can use them just fine. Just have to make sure the wiring/contactor can handle each elements rating. One element will not affect the other element, but the wiring has to be sized for each element.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Closed Thread
Proper heat elements legal_powder Oven Building Forum 2 09-29-2006 10:28 PM
Where to buy elements? Deecoat Oven Building Forum 1 08-05-2006 09:00 PM
3 phase 240volt wiring for elements edwardpic Oven Building Forum 5 04-18-2006 05:22 PM
Elements dbug10 Oven Building Forum 8 02-22-2006 10:25 AM
oven elements Blademan Oven Building Forum 1 04-02-2004 10:05 PM
