Old 12-14-2006, 08:54 AM
mtumbleson
Default Wattage question
According to the sticky thread at the top of the page, the oven I intend to build will need 8500 watts. ( 4x4x8 )
I have 4 free-be ovens that I intend to use on the project, how do I check the wattage per oven?
Old 12-14-2006, 10:06 AM
Default Re: Wattage question
amps x volts = watts
Old 12-14-2006, 02:01 PM
mtumbleson
How do I know what my existing ovens are rated at?
There doesn't seem to be any information on the out side of the units indicating what there output is. I simply want to know where I might look for this info.
Old 12-14-2006, 02:08 PM
gcastor is on a distinguished road
There should be a wiring diagram on the back panel of each oven that will tell you the elements wattage
Old 12-14-2006, 03:46 PM
mtumbleson
Thanks, I'll have to pull the panels off the backs to see what I can find.
Old 12-15-2006, 09:40 AM
mtumbleson,
Try here!
http://www.angelfire.com/pa/baconbacon/page2.html
John
Old 12-15-2006, 02:03 PM
mtumbleson
Originally Posted by jrow
Did you actually read what I posted?
  #8 (permalink)
Old 12-15-2006, 05:42 PM
I would assume he did, because he gave you a link to Ohms Law, the most basic electrical formula, and used fro calculating wattage.
measure the resistance of the element. Now take the voltage it is run at. Usually 240, devide by the resistance(ohms) that will give you the Amps that the element will draw. Now, multiply those amps by the voltage, = Watts
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
  #9 (permalink)
Old 12-15-2006, 09:01 PM
mikmj's Avatar
mikmj
Take the model no.off the stoves and go to a stove repair place. ...They should have a book on them with element size..........
  #10 (permalink)
Old 12-16-2006, 01:33 PM
mtumbleson,
Yes I "actually read" what you posted. As "The Bandit" said use the formulas. If you do find and information on the oven nomenclature plate it might be the total oven wattage and not the individual element wattage! People are only trying to help you don't be so caustic!
John
powder coat removal question eliasson Powder Coating Questions 29 04-20-2007 08:28 AM
Newbie question about coverage ublinkd Powder Coating Questions 4 03-05-2007 12:00 PM
Super wet black question petshe25 Powder Coating Questions 3 03-03-2006 04:17 PM
Peak voltage question mudwhump Anodizing Questions 6 01-14-2004 10:53 PM
Brand Newbie Aluminum Polishing Question gdsegel Metal Polishing Questions 1 04-25-2003 08:04 AM
