Great idea....I'm curious as to what glass and seal you would use around it for hi temps. I am thinking of incorporating a window/door to open and check temps and to see the coating bake as well!
I framed the opening in my door about 1/2" larger the the glass frame. Then to mount the frame/glass I just used high-temp gasket maker to glue it in place.
For the third panel I machined a frame that screws to the face of the door (6061 aluminum), then the glass is attached with high-temp gasket maker. |
we (partner & I) run a metal fab business & do lots of windows. make a frame for 1 side that is welded to the main frame, then sandwich the glass between another frame (same dimensions as the welded) that will be screwed in & as stated use high temp. silicone to provide a seal.
The reason I was wanting to know about glass is that most if not all powder states after it flows out etc. How else would I know if it flowed out. That was my thinking. Plus I'm adding lights in the doors so I can see it flow out. Thanks for the input guys.
if you can't easily see the part just tack on an extra 5 mins. cure time. flow-out usually occurs around 5 mins after you place the part in the oven, from room temp. that is. however i recommend pre-baking parts before shooting to outgass so the part will be slightly warmer when you apply the powder.
Thanks. I'm getting ready to do a cast iron three duce intake for a guy. Have baked it for around 2 hours to burn of all oils, gas etc. Don't want no out gasing. Be good for advertising. He does a lot of car shows and takes many trophies.
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 03:43 PM |
| another oven question | corybarta | Powder Coating Questions | 7 | 03-14-2005 11:07 PM |
| building a oven question | Jay87T | Oven Building Forum | 3 | 03-01-2004 05:28 PM |
| oven question | duke | Oven Building Forum | 34 | 12-11-2003 09:35 PM |
| Oven question for the Gurus | jbento | Oven Building Forum | 1 | 05-16-2003 10:33 PM |
