This is a very informative site, all except the wiring of the thermostat. I spent 1 1/2 hours the other night messin around with this thing. So now all im askin of you guys is if i show you a picture of the thermostat im workin with, do you think you can tell me how to wire it? I was'nt going to use a contactor but now i am. http://www.powdercoatoven.4t.com/Control%20box.html This is the how i want it to be wired up if possible. Thanks for all your help, Rob.
Rob, I'm assuming that you're using a regular kitchen oven t-stat. This thing is really just and ON/OFF switch. When certain temperatures are exceeded at the thermocouple, the switch is OFF. When the temperatures are below the set temp, the switch if ON.
Set the t-stat dial to OFF and take a volt-ohm meter and check continuity between all of the contacts, writing down your results. Now, set the temp dial to about 150deg and check the continuity between all contacts again. Shouldn't be much difference. Now dip the thermocouple in a pot of boiling water, let it sit for a minute or so, and check the continuity again. You should have a set of contacts that that are different from the previous setting, that is, they should be open or OFF. These contacts controlled the oven element and now will control your contactor coil in your oven. Remember, if temperature of thermocouple is at or above the setpoint, contacts will be open (element OFF). If below setpoint, contacts will be closed (element ON). |
Ok so here is what i got. I dont know if what you meant as a little difference was from .1 to .4 ohms or not, but thats the only thing that changed. I kinda drew up a rough figuration of what i got. Let me know what you think.
After studying your diagrams a bit, I believe that your thermostat may not be calibrated properly. Since contacts 1-3 and 6-7 turn on when you set the dial to 150, it would seem that these are the ones you're looking for. Turn the temp setting down just a bit, or increase the heat on the thermocouple. You may need to put the thermocouple over an open flame for a short time. If 1-3 and/or 6-7 become open (element OFF) with the addtional heat, either one of them will work to cycle the contactor.
The variance in ohms is of no consequence. Either .1 or .4 is a small amount of resistance, and that's what you want through a switch, low resistance. |
You are the man Gary!! 1 and 3 Click off when its over and open flame and i read off on my ohm meter when it clicks. So now the next question is how do i wire it up to my contactor? And in your wire box is your on/off swith just a regular 110v 2 pole switch? It's starting to make sence alot more now.
| couple of dumb newbie questions | Chunkstyle | Anodizing Questions | 3 | 02-02-2007 11:41 PM |
| A Couple Questions | HDGP | Powder Coating Questions | 2 | 05-18-2006 06:16 PM |
| Couple of questions... | Bobby-S | Electroplating Questions | 1 | 06-13-2004 04:34 PM |
| A couple carb plating questions | KenL | Plating Pot Metal | 0 | 01-23-2004 08:34 PM |
| Couple Copy Cad questions | aermakov@rogers.com | Electroplating Questions | 1 | 03-22-2003 11:17 AM |
