that design usually uses a spring... look inside any MIG welder (eh, you probly have or you wouldnt have thought of that im guessing haha) does the edge of your door have a frame? Id be worried about that flat stock pulling out of the door and bending over
Thanks for the drawing. |
This is what I'm using, my door is 4'x8', I have one on each end and you can pull it as tight as you want. Too tight actually, as I know from expericnce by pulling the metal off the outside
The "L" shaped piece there is what the latch hooks into. This can be used anywhere there is a 90* angle. They cost about $5 a piece around here.
Where did you find this one at? My door is also 4x8 and weighs a tad over 200lbs. I will probably go with 3 latches. (top, bottom, and middle). |
Ditto. I may forget about making mine. Those would work well and only takes a trip to the store, maybe? In the meantime I'm going to Lowe's and see what they have to offer.
Will report back.
Who says you can't teach an ole dog new tricks? |
i went to lowes today for closet shelving and such... still moving in here. Yeah, so i didnt even think to look for oven parts, bah... im really liking the one posted above, simple, cheap and adjustable
Well, after fighting the ice that was everywhere, I made it to Lowe's. What a waste of time.
Reworked the hinges today, as I didn't much care for the way the door was acting. It shuts better and more flat. Found I had a little bit of binding going on. Tomorrow will be busy doing a three duce manifold and gas tank for another. Plus work on the oven as much as I can.
I bought mine at the local Do-It Best store.
Anyone who carries National Hardware supplies should have these. They also make all kinds of hinges, latches, universal storm door latches, etc. The packages are white with some blue on the top with the National Hardware logo in the upper left hand corner of the package. I'll get the accurate exact part number and price of these tomorrow. If you all can't find them locally I'll pick them up and ship them to you if you want. I agree with putting 3 latches on a 4x8 door, mine is the same size and I think I need one in the middle just for added sealing measures. |
| any ideas??? | red04cavy | Oven Building Forum | 3 | 12-12-2006 02:18 PM |
| want to cad plate a carb. looking for ideas | MrPontiac | Electroplating Questions | 0 | 11-28-2006 11:37 PM |
| The Best Ideas, The best ovens | steveatv3 | Oven Building Forum | 3 | 09-22-2006 11:05 PM |
| Simple oven ideas? | euchre98 | Powder Coating Questions | 18 | 06-26-2005 11:37 PM |
| trouble with black, anyone got any ideas? | wvdon | Anodizing Questions | 1 | 03-11-2004 03:37 PM |
