Old 03-02-2007, 09:36 AM
mtumbleson
Default Powder Coating oven parts.
I have several oven parts that need painted. Would it be OK to powder coat these or would I be better off using hi temp stove paint?
Old 03-02-2007, 11:03 AM
fl70 is an unknown quantity at this point
Default Re: Powder Coating oven parts.
Probably best to use HiTemp wood stove or BBQ paint.
It ain't your grandma's box!!
Old 03-02-2007, 11:47 AM
hbracing is on a distinguished road
I think I would also use hi-temp paint but why not use these parts (if possiable) to test other powders or a ceramic coating. I will do this from time to time and did test that backer baord that some of the guys were talking about while making money coating other parts for other people. Again depends on the part and so far hi-temp paint works best for me at this point
Old 03-02-2007, 12:24 PM
mtumbleson
Its a few duct parts that I couldn't do out of galvanized because they had to be TIG welded. They will see a steady cook temp same as the inside of the oven.
Old 03-02-2007, 12:31 PM
Most of the powders state that after cure the max temp is 250 degrees.
Old 03-02-2007, 12:56 PM
mtumbleson
Thanks guys, I'll just go with stove paint.
Old 03-05-2007, 10:04 PM
JTW37's Avatar
Caswell Platinum Member
You might want to consider 1200 deg engine paint as well. I am testing it in my oven to see how it holds up. My sheet steel is bare and not galvanized, so I figured I would give it a try. I'll post the outcome after a few batches of testing.
  #8 (permalink)
Old 03-06-2007, 08:56 AM
mtumbleson
All the parts that needed painted was done with a barbeque grill hi-temp paint good to 1200 degrees. I only had 2 small fan ducts that was fabed out of cold rolled steel...
I found sand blasting aluminum prior to powder coating is a big no-no. mtumbleson Powder Coating Questions 59 04-07-2008 07:37 PM
powder coating engine parts spyoung Powder Coating Questions 1 01-20-2006 09:45 PM
powder coating oven tougher finish required d608454 Powder Coating Questions 5 07-27-2003 09:07 PM
Powder Coating Oven getastro Powder Coating Questions 14 07-26-2003 01:33 AM
