i'm too lazy to look it up (and i was here reading anyway
what is the R value of the mineral wool? debating what to use in my oven walls. i believe that the regular (unfaced) fiberglass is fine up to 500 degrees w/o a problem, and the 3.5" is R13. polystyrene (rigid foam) should also be capable of handling the temps, is R13 at 2". i could add another 1.5" foam to fill in the full cavity for another R7 (i think, forgot what 1.5" rating is). i'm just making a little guy, 3x3x6, horizontal configuration, framed w/ metal 2x4's. thanks Dave |
Don't know the for sure R value on Mineral Wool, but here is a link that may help. It's a pdf file.
Don't know if the pcf tells anything or not, but here is an item i clipped. Excellent Thermal Performance High R-Value Excellent Acoustical Performance Improves the Sound Transmission Class (STC) ratings by up to 10 dB Superior Fire Safety Flame Spread/Smoke Developed: 5/0 Noncombustible Per ASTM E 136 and CAN4-S114-M Quick Installation Easily cut with a knife http://www.specjm.com/pdf/iig416.pdf
Who says you can't teach an ole dog new tricks? |
| another simple insulation question ,mineral wool | gaskincrew | Oven Building Forum | 3 | 05-29-2006 06:31 PM |
| lining outside my mineral wool | gaskincrew | Oven Building Forum | 6 | 05-08-2006 04:19 PM |
| mineral wool | mildman61755 | Oven Building Forum | 3 | 02-13-2006 03:01 PM |
