got my windows mocked up into one of the side walls. need some high temp silicone and some bolts to finish fastening them.
tied up a few other loose ends while i was at it. now i just need to find 2 more elements, some casters and get the insulation. i can't assemble the panels until my base is complete. will get some pics later. |
the door is just a big square to cover the entire opening. i should have probably made it in 2 sections.
since the framing is only steel studs, and not SUPER strong, i will probably put a piano hinge on one side, and on the latch side, a small support wheel so the door isn't actually hanging from the hinge. |
i broke down and ordered 4 matching elements. $11 each, shipped. 2800w each. i could have found 2 more used elements, but these one should be narrow enough to mount them all on the same side of the oven. w/ the oven elements i have, the bake elements are so wide, i would have put 2 elements on each side of the oven, which isn't a big deal, just less convenient for wiring.
i also added a 2nd switch and a timer to the control box. 2nd switch is to have the timer active/inactive. once i get the elements and find some insulation, i can put it all together...but i still don't have power to the barn. Last edited by defed; 04-28-2007 at 05:58 PM. |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 04:43 PM |
| Started my new 4'x4'x6' oven.. | RNMHRD | Oven Building Forum | 24 | 02-08-2007 03:18 AM |
| An Idea -building An Oven From Cement Board | mcaswell | Oven Building Forum | 35 | 01-27-2007 10:15 AM |
| Building oven and need some help with a problem... | Nutster | Powder Coating Questions | 1 | 09-05-2005 08:42 AM |
| building a oven question | Jay87T | Oven Building Forum | 3 | 03-01-2004 06:28 PM |
