my main frame is built out of tube steel. It doesn't matter what you use as long as it will be heavy enough to hang or support what you are going to coat. Main frame meaning four corners a base and a top and tube steel because thats what I have not for any other reason. Then I am going to use 2x4 metal studs around this to form the walls for the the insulation. The frame will be welded and the studs either riveted or screwed but the skin will be screwed so if there is a problem or I want to add on to it at another time I can take it apart. Good luck........................
| Newbie oven questions (electrical) | kcdonahue | Powder Coating Questions | 11 | 02-22-2007 06:21 PM |
| Newbie oven questions (electrical) | kcdonahue | Oven Building Forum | 9 | 01-16-2007 03:57 PM |
| Zinc Plug N Plate Dark Streaks/Coverage Capacity Questions | ms042180 | Electroplating Questions | 3 | 12-21-2006 12:48 PM |
| Questions on PCing HD wheels | oldgoat69 | Powder Coating Questions | 4 | 06-02-2006 09:56 PM |
| Questions from a wanna be... | cusackmusic | Anodizing Questions | 1 | 01-09-2004 04:45 PM |
