Old 03-09-2007, 08:30 PM
mtumbleson
Default My oven 4x4x8
Oven front with 2 windows (4 panes of glass per opening)
http://www.lukescustoms.com/Oven_front.JPG
http://www.lukescustoms.com/window.JPG
Access panels. These are used on both sides and the back so I can get to the wiring with out having to remove the entire panels. They will be screwed on instead of rivited.
http://www.lukescustoms.com/access_panel.JPG
This is the door latch assembly.
http://www.lukescustoms.com/door_latch.JPG
The door weighs rith at 200 pounds. I didn't want all that weight hanging on the hinge all the time. I cam up with this to help support the weight.
http://www.lukescustoms.com/door_support.JPG
http://www.lukescustoms.com/Oven_door_support.JPG
Here is the fan mounted at the back of the oven. It pulls the air from the top of the oven then is directed to the bottom of the oven through a duct inside the oven.
http://www.lukescustoms.com/fan.JPG
Inside the oven, at the top is the inlet to the fan, the black part is the duct returning the air to the inside of the oven.
http://www.lukescustoms.com/Inside-_fan_ducts.JPG
This shows the 2 interior lights and the air duct releasing the air 1 foot from the bottom of the oven. The Idea of running the return air down the inside of the oven is that it will be re-heated on the return. I do loose a little area inside the oven, but I think this will work fine.
http://www.lukescustoms.com/inside_oven.JPG
Picture of the Panio Hinge
http://www.lukescustoms.com/Panio_hinge.JPG
This thing is sitting on casters so I can move it around my shop.
It is built with 18g gal. inside and out.
All I have left to do is purchase my wire and ss wire conectors the hook it up.
Hope this helps someone with their build. All the parts used were from information found here on this forum.
Thanks for all the help.
Old 03-10-2007, 01:16 PM
Default Re: My oven 4x4x8
Very nice job!
Old 03-10-2007, 04:34 PM
mtumbleson
Thanks.
Old 03-10-2007, 06:58 PM
hbracing is on a distinguished road
Nice work!!!!!!!!!!! Looks like what I have in mind!!!!!!!!!!!!!!
Old 03-10-2007, 07:53 PM
JTW37's Avatar
Caswell Platinum Member
That is every powder coaters dream. Nice outfit. Very well done. Mine should be so nice.
Old 03-10-2007, 08:40 PM
mtumbleson
Thanks guys, all I have left to do is locate wiring and stainless wire conectors any ideas where I can get that stuff?
Old 03-10-2007, 08:49 PM
fl70 is an unknown quantity at this point
Lookin' good.
Why stainless wire connectors?
It ain't your grandma's box!!
  #8 (permalink)
Old 03-10-2007, 11:39 PM
mtumbleson
I was told that a standard connector wouldn't hold up to the heat..
  #9 (permalink)
Old 03-14-2007, 07:51 PM
BerkelUSA's Avatar
BerkelUSA is an unknown quantity at this point
Send a message via AIM to BerkelUSA Send a message via MSN to BerkelUSA Send a message via Yahoo to BerkelUSA
Thumbs up Re: My oven 4x4x8
They make ceramic ones (worked in foodservice on electric ovens for over 16 years)
But of course I dont think they were too cheap..
NICE OVEN!
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
  #10 (permalink)
Old 03-14-2007, 08:07 PM
mtumbleson
Thanks.
I found high temp wire connectors on McMaster-Carr's website.
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 03:43 PM
What will i need to build a oven 8x4x4 Catmando Oven Building Forum 7 07-25-2007 09:50 PM
Newbie oven questions (electrical) kcdonahue Powder Coating Questions 11 02-22-2007 05:21 PM
Oven problem !!!!! tavo1765 Powder Coating Questions 7 10-06-2005 05:21 PM
