Old 03-17-2007, 05:26 PM
hp246 is on a distinguished road
Default Plug Question
OK,
I have a 220 compressor in my pole barn. I ust got a free oven for my powder coating projects. The plug on the oven is different. Since I probably woun't run both the compressor and oven at the same time, I was thinking of just plugging into the same outlet. The oven has a different plug. Can I just swap out the plug? Or will I need something different power wise, and need to run a new wire from the box along with a range type receptical?
Old 03-18-2007, 08:26 AM
hbracing is on a distinguished road
Default Re: Plug Question
The wiring going to your compressor is probable to small to run the oven and like wise the breaker. If you size everything for the oven it will be to big for the compressor. The compressor will run but will NOT have the protection it needs. Another words if the compressor over loads it won't trip the breaker (because it's rated for the oven) and will burn up instead and may catch fire. It certainly can be done but you have to be very careful and if your garage burns down your insurance will not be happy..................
Old 03-18-2007, 09:23 AM
JTW37's Avatar
Caswell Platinum Member
Besides that, a four wire with the ground is a real good idea. No shocks for you. Do the wiring it's safer and better. You will be glad you did.
Old 03-18-2007, 10:47 AM
Thanks. Its not a big deal to run the wiring, just would have been simpler to do it other wise.
Zinc Plug N Plate Dark Streaks/Coverage Capacity Questions ms042180 Electroplating Questions 3 12-21-2006 12:48 PM
Question about plug and plate. tomg552001 Electroplating Questions 1 05-15-2003 01:06 AM
Plug N Plate Question carmelmike Electroplating Questions 1 03-20-2003 07:10 PM
Plug N Plate Copy Chrome question Great_Scott Electroplating Questions 5 03-20-2002 06:53 PM
