Old 03-17-2007, 05:17 PM
willy535 is on a distinguished road
Default another?do you really need high temp wire
hi,just started my oven,going with steel studs.have learned alot from this forum and am very confident.do you really need hi-temp wire.all of my wiring will be in the walls.i have a boat load of 10g awg that a buddy gave me and hi-temp is like 4bucks a foot....enlighten me
Old 03-17-2007, 06:01 PM
krymis is on a distinguished road
Default Re: another?do you really need high temp wire
you only need hi temp in the oven to connect the elements. The sheating of regular wire will not hold up. I learned this from jason and my build of the pregnant oven.
Old 03-18-2007, 07:17 AM
hbracing is on a distinguished road
better safe than sorry.when it comes to electricity aways go by the rules. Thats a fire waiting to happen!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-18-2007, 08:17 AM
JTW37's Avatar
Caswell Platinum Member
I also put fuses in line with everything, just in case. If it shorts, the fuse will stop it in it's tracks before a fire.
Old 03-18-2007, 09:32 AM
mtumbleson
You can get 14g/50 amp (high temp) wire at MacMaster-Carr for $2 per foot.
I can't give you a direct link, but search for "wire" then select "appliance wire" and choose your ratings as needed.
Old 03-18-2007, 05:20 PM
looking around,i can get it cheaper.i did a google search.i must use at least 12 gauge.....will
Old 03-18-2007, 06:36 PM
I have scrounged heaters, and thermostates out of old ovens. But dont stop there, the insulation and the wire could also be reused. This brings down the price of oven building considerable. I know that there is not much insulation, but every little bits helps in a pinch and I can be the king of penney pinching especially when it comes to experimenting. I am not a fan of wasting money, it's to hard to come by these days....................
  #8 (permalink)
Old 03-19-2007, 11:34 AM
Check out here
http://www.tevelec.com/CatalogProduc...ProductsID=119
It's where I have goten wore for both my ovens. Real good price. Take it from an Electrician, you can never be to carefull when it comes to electricity.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
  #9 (permalink)
Old 03-19-2007, 02:56 PM
well,i'm going to have to do a littler researching.i've only done basic household wiring and it seems your average awg wire is totally different than tggt wire(or any other high temp)when i use 12g wire at home its usually rated for 20amps.but it seems hi-tenp 12g is for much higher amperage.is this correct.so,if i'm using 3-3000 w elements....37.5 anps per my calculations.i can get away with 14 or 16 g tggt.....ELECTRICIANS....help.....will
  #10 (permalink)
Old 03-22-2007, 03:56 PM
mtumbleson
If you follow the instructions I gave you to search McMaster-Carr from above, they will is the amp rating with the wire they sell...
High Temp problems. ctx97 Powder Coating Questions 1 12-26-2006 11:49 PM
High Temp Ceramic powder lfsracing Powder Coating Questions 7 10-06-2006 11:10 AM
high temp sheeting craigcraig Powder Coating Questions 1 08-09-2004 12:15 AM
any experience w/ high temp on headers RossL Powder Coating Questions 2 05-05-2004 08:11 PM
Can I use VHT high Temp with Krylon High temp radiator paint magnus Other Metal Finishing Questions 1 05-03-2003 11:20 AM
