  #11 (permalink)
Old 03-22-2007, 01:15 PM
mtumbleson
Default Re: Stainless steel refrigerator.
The way mine is constructed, removing the foam is not a viable option. Really the only thing I can think to do would be to construct a new liner. At any rate it will still take less money and time to do that rather than starting from scratch.
  #12 (permalink)
Old 03-23-2007, 12:40 AM
defed is on a distinguished road
from what i've read, most of the foams will deteriorate at 400+F. i have some foil faced polyiso that i had read was good to 300F, but when i emailed the mfg, they said 250F only. the polyiso is good to higher temps than polystyrene in general.
i plan to use 2" mineral wool on the heat side and i will put the 1.5" polyiso on the outside of that for a full 3.5" insulation and close to R17 total.
  #13 (permalink)
Old 03-23-2007, 06:19 AM
Hobweld is on a distinguished road
I played the foam removal game. Not fun but not all that bad either. I found the foam stood up to most anything I threw at it to dissolve it. Found the quickest way to remove it was with a air hammer and a wide chisel blade. Then I just built a liner for it. Good luck.
Ken
Plating stainless steel watchcase with white gold fredj Electroplating Questions 1 06-03-2007 05:58 AM
Tin plating stainless steel jgdpd Electroplating Questions 0 06-12-2006 04:46 PM
Polishing Stainless Steel mboyd3 Metal Polishing Questions 3 07-15-2005 03:39 PM
Chrome on stainless steel Fick Other Metal Finishing Questions 3 07-05-2005 01:27 PM
Stainless Steel Help, Please rbkemp25 Metal Polishing Questions 4 06-21-2003 07:59 AM
