Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 04-02-2007, 12:06 AM
Biznatch is on a distinguished road
Default Oven wiring
I have an oven that I picked up that doesnt work. Instead of trying to fix the existing stuff I think it would be easier to get a temp controller and hook it up to the existing elements. So can I use these parts and have everything work properly? Thanks.
http://cgi.ebay.com/NEW-CN-PBC303-24...QQcmdZViewItem
http://auberins.com/index.php?main_p...products_id=14
The oven can controll the fans by itself so I will just be wiring it up to the heating elements.
Old 04-02-2007, 01:16 PM
mtumbleson
Default Re: Oven wiring
That's a pretty big expanse just for a repair. It may just be the thermostat. I would get an ohm meter ant check it, it's real easy.
I have several house oven thermostats I would sell one for real cheap if your interested.
Old 04-02-2007, 03:27 PM
Well it's a double oven and neither one will heat up. Since they have seperate thermostats I don't know how likely it is that they both failed at the same time. When I check them with the OHM meter what range is in spec? or does that differe between thermostats. (Oven is a thermador, dont know model since that sticker seems to have been removed. It's just a double wall oven.)
Closed Thread
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 04:43 PM
oven wiring? hog1340 Oven Building Forum 0 07-20-2006 08:03 AM
Wiring a simple two element oven... wamontgomery Oven Building Forum 1 03-19-2006 03:49 PM
Wiring (GE Appliances) oven upncoming Powder Coating Questions 6 07-18-2004 07:45 PM
