I have been reading this forum for a few weeks now and am starting my oven.
The outer dimensions are 4x4x7 The frame is 2" square tubing Insulation will be 2" mineral wool Outer covering is 22 gauge sheet metal Inner covering is 18 gauge metal Freezer latches to hold door shut There will be a divider halfway up made up 2" tubing and insulated. The plan is to be able to just run the top half of the oven except when larger parts need to be baked. For the electrical, I am most likely getting the digital controller that so many here seem to be using. The TET612 seems like a good unit sold by coldfusionx on ebay. Now here is where my questions come in. I was trying to determine if 4 1800w elements would suffice for this oven or would I have issues maintaining temperature stability. My main concern is that if I go up to 2500w elements I would have to much draw on my available power (available amps). I would most likely only be running 2 elements 75-80% of the time anyways. What contactor would best work in this oven? |
I would use the smaller elements and set it up so that you could manually shut what you don't need when you are at half capacity. Use 1 contactor for each element and you will have the control you want. It will add a few more bucks but from what you discribed, sounds like a sweet set up, and is pretty much what I am building. Spend the few extra bucks and have the control you are after and you won't be sorry..................
To answer the question, The contactors sizes are determined by the element sizes. Be sure your contactor is rated for the use, and a little more certainly will not hurt...................
Maybe if you could get your hands on MIL-H-6875 this may provide you with some guide lines. It's a good base specification which I have used in setting up other heat treating shops. Michael
If the oven is temp controlled does it matter rather some or all the elments are on? Provided you have the power to run them all at once.
I mean 500F is 500F right, rather fast with 4 elements or twice as long with only 2 elements, it's still the same power used to heat and hold the oven at 500F. Or am I missing something? New to this and going to try building my own oven soon. My plans are to use parts from junk house stoves, Electric ranges are trashed all the time while still working, I can get them at scrap yards for $10 or less. I would think all theparts are there, I just have to install them into a new cabnit and wire them up. |
I built my first oven and have been using it for a few weeks now. I have a wiring diagram posted with photo's of my oven build. Now I wish i would have used heavier gage steel for the walls, but it works fine, it just makes heating groans
Mine is 28 ga. (should have used at least 20) 3x3x6 and is pretty much a good size. I am currently building one half the size, 3x3x3, of the big one. Most of the parts I'm coating are automotive related. Follow the link for a look if you want.http://s80.photobucket.com/albums/j1...20Coat%20Oven/
Who says you can't teach an ole dog new tricks? |
