Old 04-23-2007, 01:30 PM
donafams is on a distinguished road
Question Metal Stud Frame
does anyone weld these metal studs together or just rivot?
Old 04-23-2007, 01:49 PM
hbracing is on a distinguished road
Default Re: Metal Stud Frame
use a self tapping flat headed screw. Its fast and easy
Old 04-23-2007, 01:58 PM
and you can sheetmetal over those ok?
Old 04-23-2007, 02:06 PM
Sure because the head of the screw is real flat. I personelly am screwing the sheet metal on also. The reason is there will be wire behind it and if I have to take it apart i can do so with out a lot of trouble. Self tapping screws are just easier, but I am sure there are guys who will disagree and thats fine. This is my preference but doesn't make it right for some one else. Good Luck
Old 04-24-2007, 12:31 AM
speeddemonrodsteration's Avatar
I'm welding mine, just remember to have good ventalation when welding galvanized! I welded just cause I like welding stuff, I'm just welding the frame togather- I'm also screwing on the sheet metal for the same reason as above.
Save the trees- burn Rubber!
Old 04-24-2007, 09:38 AM
autobonifica is on a distinguished road
Send a message via AIM to autobonifica
i also riveted mine...then welded the seems for added strenth
Reactive Coatings
Old 04-24-2007, 01:22 PM
I welded mine, took me a while, but she is totally solid now.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
  #8 (permalink)
Old 04-25-2007, 10:42 AM
why am i having so much trouble finding self tapping screws in a flat head
  #9 (permalink)
Old 04-28-2007, 12:46 AM
Are you asking for the screws for Metal Studs?
Dan Pesonen
Personal motto:
  #10 (permalink)
Old 04-29-2007, 07:48 AM
ah, i just welded the studs, seems stronger anyway
PLATING POT METAL............... 48Buick Plating Pot Metal 31 08-29-2007 11:40 AM
thin areas on bike frame using metallic datadawg Powder Coating Questions 6 01-25-2007 08:42 PM
PC'ing an old truck frame... dansilbaugh Powder Coating Questions 5 07-22-2005 04:11 PM
Refinishing Metal Golf Club Heads BillSchultz Other Metal Finishing Questions 0 08-17-2003 10:40 AM
