glue the flat part of it with high-temp mortar & rivet it every 5 inches or so.
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
u can find high-temp mortar @ any hardware store. it comes in a caulking tube & is ~ $3/tube. rated to something like 1200 deg F.
ooooh. should have got the seal with the tail. it's easier to install, but not a big deal.
Just glue it in place with good quality RTV silicone
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
sure, either will work fine, however if you are budget conscious the mortar is a way better deal. you get 3 times as much in a tube for 1/2 the price & it is easier to work with.
are you saying the high temp mortar is similar to a silicone/caulk type product? when i see 'mortar' i think of a cement/sand based product. i have seen the 'mortar' but figured it wasn't what i wanted.
| trouble locating door seal | TurboRoadster | Oven Building Forum | 15 | 01-17-2007 04:39 PM |
| Zinc plating on running seal surface? | Broke | Electroplating Questions | 1 | 12-06-2004 01:52 PM |
| What is the best way to seal my part after polishing | krsimulis | Metal Polishing Questions | 2 | 05-29-2004 09:03 PM |
| Zoop Seal - Does it really work as advertised | chefwong | Metal Polishing Questions | 2 | 05-11-2004 05:43 PM |
| Zoop Seal | etyrrany | Metal Polishing Questions | 2 | 10-04-2003 09:34 AM |
