Old 05-29-2007, 02:42 PM
bigfoot53's Avatar
bigfoot53 is on a distinguished road
Question Mounting Elements ?
Hey All,
I have a question about mounting the elements in my oven. after looking in the forum i have seen elements mounted both horizontally and vertically is their an advantage to either one ? i am building a 4' x 4' x 6' oven
thanks
Bruce
Old 05-29-2007, 04:49 PM
CarWiz's Avatar
Default Re: Mounting Elements ?
Probably not but it might depending on the size and shape of the item you're cooking and where it's located in the oven. Heated air rises. As it does, it draws cooler air up from below the elements. When mounted vertically (on the sides), the upper portion of the element could run a little hotter but this position could provide better movement of air through the oven. The draw back is that it may allow larger cold spots in the oven. Most likely at the upper and lower center and against adjacent walls.
I haven't heard anyone complain about vertically mounted elements but I've heard a lot of complaints about getting a correct temp reading from a controller. This appears to be the reason many use a point and shoot thermometer. That could be cured by proper placement of the thermocouple and it's controller settings (Input Offset) as well as piece placement.
Old 05-29-2007, 05:23 PM
nuttyman's Avatar
nuttyman
if they are mounted vertically you have more space on the floor if you ever need to place something directly on the floor. proper convection eliminates the cold-spot theory too.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Verticle Elements donafams Oven Building Forum 1 05-17-2007 12:59 PM
Strip Elements pootsman55 Oven Building Forum 0 02-11-2007 06:53 PM
Where to buy elements? Deecoat Oven Building Forum 1 08-05-2006 08:00 PM
3 phase 240volt wiring for elements edwardpic Oven Building Forum 5 04-18-2006 04:22 PM
Elements dbug10 Oven Building Forum 8 02-22-2006 09:25 AM
