That would probably work although it's a little pricey. I got two of these for $8 each. The Fasco still has to have the motor outside the hot area.
http://www.surpluscenter.com/item.as...tname=electric |
that's a great deal but it does not say anywhere that they are high heat blowers. are they?
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
Not trying to be negative, but.. the blade will be 400F as well as the shaft. Which means the bearings probably won't last long.. and the shaft carrying that heat right into the motor.. same deal.
Won't hurt to try for the price |
It ain't your grandma's box!! |
I can't remember the grainger part number, but my high heat fan was around $300 CDN
Ahh, just found it Dayton blower Model 4YJ33 can see it here http://www.electricmotorwarehouse.com/dayton_blower.htm
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" Last edited by Banditperformance; 06-09-2007 at 09:46 AM. |
use the induced draft fan blower set up off of a furnace. Some are plastic and some are steel and if you have connestions with an HVAC guy he can probably get you one off of an old unit for nothing. Even new ones are under $100.00. My personnel preferance are the free ones they work great!!!!
| How well does powder stick to part before baking? | chromo | Powder Coating Questions | 4 | 05-03-2007 11:22 PM |
| How do you determine the proper duct size for a fan duct? | mtumbleson | Oven Building Forum | 15 | 02-26-2007 10:32 PM |
| Part cleaning. | nil8u | Electroplating Questions | 9 | 08-22-2006 12:23 PM |
