Old 06-25-2007, 04:49 PM
holeshot87
Thumbs up parts cleaner
does someone know a good parts cleaner. before i powder coat a part i have been using brake cleaner. .is there something easier to use then brake cleaner and better? thanks
Old 06-25-2007, 07:56 PM
hbracing is on a distinguished road
Default Re: parts cleaner
thats what i use. Lacquer works well also. If any question on how clean the part is pre heat the part first so it does not outgas. this process seems to work for me.......good luck
Old 06-28-2007, 09:56 PM
JTW37's Avatar
Caswell Platinum Member
I have used Paint shop Metal Prep, Alcohol, EW Pre as long as it has NO petroleum in it. I also use Simple Green to do cleaning and then wipe it down with any of the ones I listed. They all seem to work. Just before you shoot the powder on, use a small propane torch and just quickly go over the part to get rid of the fuzzies and dust that collects on the part. Don't get it to hot. The little sparks you will see are the fuzzies getting burned up.
Old 07-01-2007, 12:52 AM
precise is on a distinguished road
Akline base cleaner works real good, this is what you can do, Call a local air conditon suplly house a place where they sell air condition parts, tell them or go by and pick up some "coil cleaner " that stuff works great , you buy by the gallon You then delete it down works real good It will go a ong way ,,, This stuff is what i use,,
Old 07-01-2007, 01:55 PM
holeshot87
Smile Re: parts cleaner
everyone thanks for the information.this helps out alot.
Old 07-17-2007, 08:32 PM
FOXCONCEPTS is on a distinguished road
Simple Green...
i do alot of motorcycle parts, i use a 2800psi pressure washer then i use paper towels and simple green then torch it
what parts cleaner solvent boink117 Powder Coating Questions 4 06-16-2007 02:27 PM
Nickel-plated parts in an ultrasonic cleaner KongaMan Metal Polishing Questions 2 05-09-2007 05:05 AM
7000 series parts dye, but 6000 series won't acidrain Anodizing Questions 20 11-17-2005 10:19 PM
Copy Chrome on engine parts and plastic, alot of can I's cgworth Copy Chrome Kit Customers Only 3 08-29-2005 12:38 PM
trouble with black, anyone got any ideas? wvdon Anodizing Questions 1 03-11-2004 02:37 PM
