Results 1 to 5 of 5
Thread: element wattage
  1. #1
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Default element wattage
    hi , if i have an element and i want to know how many watts it is and nothing is stamped on the bracket how do i proceed
  2. #2
    JTW37's Avatar
    JTW37 is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Feb 2006
    Location
    Bristol, In
    Posts
    776
    Default Re: element wattage
    Hi Baz
    Don't know if I know that, but what I have found is someties they put that (watts) info on the element itself. Sometimes you need to get out the magnifying glass to see it, but I have found it that way or just have my Son read it. small print.
    Just found this in the past post.
    measure the resistance of the element. Now take the voltage it is run at. Usually 240, devide by the resistance(ohms) that will give you the Amps that the element will draw. Now, multiply those amps by the voltage, = Watts OR
    go here and put in the number that you know.
    http://www.angelfire.com/pa/baconbacon/page2.html
  3. #3
    baz
    Join Date
    Feb 2006
    Posts
    822
    Quote Originally Posted by JTW37
    Hi Baz
    thanks for the link ,that s what i was looking for.
  4. #4
    BottleFed70 is offline Amateur Metal Finisher
    Join Date
    Apr 2007
    Posts
    90
    You should be able to measure the resistance to get an idea. Resistance changes with temperature a little, but should be close.
    Power = Voltage * Current
    Current = Voltage / Resistance
    With simple algebra we can thus say that power = (Voltage * voltage) / resistance
  5. #5
    precise is offline Newbie
    Join Date
    Apr 2006
    Posts
    42
    Measure your voltage, then your amps, Multiply the two there you go you got the watts
Thread Information
Users Browsing this Thread
  1. dryer element
    By bjmill81 in forum Oven Building Forum
    Last Post: 02-27-2007, 01:09 AM
  2. adding an element
    By ironrose in forum Oven Building Forum
    Last Post: 09-12-2006, 04:25 PM
  3. type of element
    By baz in forum Oven Building Forum
    Last Post: 07-10-2006, 07:43 PM
  4. wiring broil element
    By gaskincrew in forum Oven Building Forum
    Last Post: 04-08-2006, 12:24 AM
  5. oven broiler element ?
    By buzzurd in forum Powder Coating Questions
    Last Post: 07-24-2004, 10:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
