Just finished building this oven which is a box within a box insulated with rock wool insulation. I used 6000 watts of heating elements and a Robert Shaw oven bulb type cotroller. My concern now is the controller has about a 10% control range. Can I get away with that great of a control range? Thanks.
if i understand you correctly...you mean that the temp can fluctuate +/- 10%?
that's an 80* swing. i personally think that's too much
Reactive Coatings |
Better said would be plus or minus 5% control range. I have checked it at 400 degrees and have a 35 degree swing in temp between off and on. It seems like after a few cycles the swings grow smaller.
there should be some settings where you can change that. and it's getting smaller because the controller is trying to figure out how to keep the temp level (cycle rate and time). does your controller have an auto-tuning feature? if so...use it.
i have mine set to a +/- 3* tolerance
Reactive Coatings |
Its amazing, the PID controller is installed along with the SSR, the Temp comes to the setpoint and just stays put. The controller pulses the SSR to maintain the temp within one degree of setpoint. Now I have this old comercial 2 pole 30amp oven controller setting on my bench,anybody know a use for it? Its a bulb type of controller. Its not heavy enough for a boat anchor.
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 04:43 PM |
| Oven temp vs part temp | getastro | Powder Coating Questions | 4 | 10-01-2007 01:53 AM |
| What will i need to build a oven 8x4x4 | Catmando | Oven Building Forum | 7 | 07-25-2007 10:50 PM |
| Wood Charcoal oven? | chromo | Oven Building Forum | 6 | 05-17-2007 02:11 PM |
