Old 08-28-2007, 11:48 PM
sawman is on a distinguished road
Default elements
how many watts would you guys recamend for a oven 30" wide 40" deep 7' tall with 2" of insulation?
thanks
Ed
Old 08-29-2007, 10:14 AM
nuttyman's Avatar
nuttyman
Default Re: elements
10 -15 kW would suffice
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 08-29-2007, 12:27 PM
ed_denu is on a distinguished road
You might try this calculator previously posted:
Temperature Time to Rise Calculator
Old 08-29-2007, 08:59 PM
BottleFed70 is on a distinguished road
x2
I think the estimate of 10-15Kw is a little high. I'd look in the 8-10kw range, but use the calculator......
Old 08-30-2007, 01:45 AM
outcastzeroone
anyone care to run to see what size i would need for a 5x2x2 oven. I run mac and excel wont run on my OS.
Old 08-30-2007, 09:42 AM
I can but you need to supply a couple of parameters:
starting temperature
target temperature
element watts
program returns heat-up time based on these variables.
Example for a 2x2x5 oven, starting at 80 degrees and heating to 400 with 5170 watts(23 amps) of heating elements takes 10 minutes and 19 secs to reach 400.
If you increase the element size to 10000 watts(42 amps) it would reduce the heat up time to 5 min 20 secs.
Old 08-30-2007, 10:42 AM
nuttyman's Avatar
nuttyman
10-15kW isn't too high. it would enable that size oven to reach cure temp twice as fast as a 7.5kw oven which would also work, albeit with a little more complicated wiring scheme.
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Verticle Elements donafams Oven Building Forum 1 05-17-2007 12:59 PM
Oven elements - Grill elements? KKamel Oven Building Forum 2 12-29-2006 08:48 PM
Where to buy elements? Deecoat Oven Building Forum 1 08-05-2006 08:00 PM
Elements dbug10 Oven Building Forum 8 02-22-2006 09:25 AM
oven elements Blademan Oven Building Forum 1 04-02-2004 09:05 PM
