Old 10-15-2007, 05:52 PM
donafams is on a distinguished road
Question Inside of Oven Coating?
my 6x3x3 oven has the interior lined with sheetmetal, just like th eoutside, but its starting to look nasty. does anyone coat the inside with anything?
Old 10-15-2007, 08:28 PM
ed_denu is on a distinguished road
Default Re: Inside of Oven Coating?
I made mine with galvanized sheet, so it looks about the same as always. I'm not sure what you could do with it, considering the heat it is subjected too.
Old 10-15-2007, 08:33 PM
mine is gal sheet also, but is looking nasty
what if the inside was sprayed with high temp paint?
Old 10-15-2007, 11:54 PM
mikmj's Avatar
mikmj
I used hi temp chrome paint from napa
Mike
Old 10-16-2007, 09:28 AM
Since we both used galvanized steel, I'm curious as to what is causing it to look bad? Is it heat discoloration, rusting? Any pictures.
Old 10-17-2007, 02:10 AM
chromo
I wonder also why it looks bad.
My first thought would be you could coat it with high temp powder perhaps. What is your normal bake temps??
Old 10-17-2007, 12:17 PM
caseywan is on a distinguished road
I had the same problem...
Mine is 8x3x4 and was made from galvanized sheet metal, but when I bought it I had to drive 8 hours home and it POURED rain almost the whole way with the oven in the bed of my truck. So when I got it I dried it the best I could with towels and blew it out and then let it sit outside in the summer heat to dry itself for a couple days and then it had some serious surface rust problems.
I bought Rustoleum high temp paint they make for Barbecue grills and stuff. I rolled it on the inside and outside and it's only been 3 or 4 months but it is holding up great. I figure if they make it for grills and will hold up to hours of direct flame, it should hold up in a 400* oven just fine.
  #8 (permalink)
Old 10-19-2007, 01:27 PM
Rikardi151 is on a distinguished road
I am using a metal cabinet as an oven. Is tehre any problem ith its current coat of paint? should I strip it and spray over it with something else?
  #9 (permalink)
Old 10-22-2007, 08:00 AM
JTW37's Avatar
Caswell Platinum Member
Been awhile since I posted, But to answer your question, I used the Hi Temp Engine paint. I put it on about 10 months ago and it's held up real well. I've had my oven up to 600 deg and it don't seem to bother it, But then it is supposed to be good to 1200 deg. The brand I used was Dupli-color available at most Auto Parts Stores. I used Silver, of course.
My oven is 6x3x3, so get about 3 or 4 cans to do the job. Wear a mask, cause it gets thick inside while your spraying.
What is the best coating for the inside of an exhaust manifold? x1rider Powder Coating Questions 7 01-03-2007 10:06 AM
Powder Coating Inside of Rim??????? chcustom Powder Coating Questions 2 10-25-2006 09:14 AM
Paint or Coat inside of oven? ty1295 Oven Building Forum 1 03-30-2006 11:27 AM
Coating the INSIDE of Headers???? JNizzle Powder Coating Questions 6 05-07-2005 11:53 PM
Powder Coating Oven getastro Powder Coating Questions 14 07-26-2003 01:33 AM
