Old 10-15-2007, 06:30 PM
donafams is on a distinguished road
Question Cleaning Tank ??
anyone have a cleaning tank, maybe like Harbor Freight sells, but with much harsher chemicals than just degreasers
Old 10-15-2007, 08:31 PM
ed_denu is on a distinguished road
Default Re: Cleaning Tank ??
I use kerosene in my parts washer. If you're talking about something like stripper, I think most people use plastic drums or something similar. Search the powder coating forum at Eastwood for some suggestions.
Old 10-16-2007, 12:11 AM
CarWiz's Avatar
What kind of "harsh" chemicals are you thinking about? I used the liquid concentrate cleaner in mine and it promptly ate the paint from inside the tub. (overnight) It also caused a lot of corrosion to cleaned parts.
It's pricey but I switched to naptha in the shop cleaners. I occasionally add about a quart or two of lacquer thinner to boost cutting power. All the others just seem too oily to me.
Old 10-16-2007, 06:29 AM
one that will disolve paint, and powder coat. like the spray stuff, but something i can immerse the part into to do a better job
Old 10-17-2007, 01:57 AM
chromo
Hello Don, Dona? Not sure which yet?
"one that will disolve paint, and powder coat."
WELL, I found that soaking a ford valve cover in 1 part simple green 10 parts water has removed the paint fairly well in 24-48 hours. I was only wanting to degrease the part but hose it down with a simple water hose and nozzle blows off the paint also. However, the black pulley's on a ford engine the simple green even straight does not seem to remove. For this I think a soak in LYE/water works. It has worked on a couple test pulley's but I am not sure the strength I mixed now.
Not tried to strip aluminum, lye will not work and eats aluminum!!!
Lots of stuff out there, if working with plain steel I would try a strong lye water mix. Be very careful as any in the eyes can be blinding and burns skin, but same with many other more expensive things also!
Self cleaning Hexhead Oven Building Forum 5 05-07-2007 09:34 PM
Gun cleaning gcastor Powder Coating Questions 12 10-24-2006 05:06 PM
cleaning norsky Powder Coating Questions 1 02-20-2006 08:33 AM
PC Gun Cleaning jbotti1 Powder Coating Questions 4 02-15-2006 08:21 AM
Cup Cleaning garykelly Powder Coating Questions 2 07-05-2004 10:59 PM
