Old 11-09-2007, 12:01 AM
bhooge is on a distinguished road
Default Oven Build Questions
Hi all,
I happened to latch on to a stainless steel blanket warmer (seems to be insulated very good..at 250 the outside is only warm to the touch) at the hospital I work at and would like to convert it to a PC oven. It is about 5 cubic ft and presently has one of those silicon/kapton heating elements on the bottom and can only reach about 250 degrees. If I was to get one 2000 watt bake element to replace this one and the following parts would they all work together for what I am trying to do here? Would one element heat this to 400+ degrees? Thanks for any and all help with this.
1-universal 1/32 DIN PID temp controller
1-40 amp SSR
1-K-type thermo-couple
(all the above from Auber instruments)
1-2000 watt bake element
Brian
Old 11-09-2007, 08:23 AM
ed_denu is on a distinguished road
Default Re: Oven Build Questions
Brian, One 2000 watt element should easily heat 5 cu ft. If you buy your parts from auber they should all work together.
I'm not sure they make 2000 watt 120 volt elements, but if you could find one it would eliminate the need for a 240 volt circuit. PID, SSR, etc would work with either.
The 40 amp SSR is more than adequate as the 2000 watt element would consume a little over 8 amps at 240 vac and twice that at 120 vac.
Old 11-09-2007, 08:49 AM
ed,
I would do that but the warmer as it is now says not to exceed 7 amps. I already have a 220 outlet in my garage so it will not be a problem going that route. I just wanted to make sure al the parts would work together and make the wiring simple. Thanks a bunch.
Brian
What will i need to build a oven 8x4x4 Catmando Oven Building Forum 7 07-25-2007 09:50 PM
My oven build misterwelder Oven Building Forum 2 01-15-2007 12:01 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 10:40 PM
i want to build an oven suprtong Powder Coating Questions 4 03-11-2005 01:43 AM
How to build an oven Sezer Oven Building Forum 2 12-24-2003 03:42 PM
