  #91 (permalink)
Old 03-13-2008, 04:27 PM
Willis is on a distinguished road
Default Re: GatorHyde oven
Originally Posted by GatorHyde View Post
Fan install. First I think I will say that if I was building another oven I would frame 1st, sheet the inside, element/fan/light install, wire, then insulate. Live and learn. With that said, I removed the back sheet metal and insulation to install the fan. Measured, and centered, cut the 5" hole, ground it as "round" as possible and drilled the fan mounting bolt holes. Before permantly installing it I am going to put a bead of RTV high temp seal around the round hole where the fan meets the sheetmetal.
Are u using the fan as an exhaust or to circulate the hot air?? Or Both??
Just trying to understand thats all.
  #92 (permalink)
Old 03-13-2008, 06:25 PM
GatorHyde's Avatar
GatorHyde is an unknown quantity at this point
Re-circ hot air.
GatorHyde of Denver
10650 Irma Dr. #24
Northglenn, CO 80233
303 280-3056
  #93 (permalink)
Old 03-21-2008, 12:06 AM
simplytodd is on a distinguished road
Man that does look very good. I'm going to be building an oven in the next couple weeks.* I'm wondering if instead of sealing the inside with caulk, can the seams just be welded together?
  #94 (permalink)
Old 03-21-2008, 12:22 AM
wetdream is on a distinguished road
What happens if you have to remove a panel for repair once welded not to mention you would burn the Galvanized off!!??
  #95 (permalink)
Old 03-21-2008, 05:52 AM
Fox Fox is offline
Fox is on a distinguished road
From what i understand welding galvanized will bring out toxic fumes so you might be better using sealant instead.
  #96 (permalink)
Old 03-22-2008, 07:12 AM
JTW37's Avatar
Caswell Platinum Member
A true statement about the Galvanize. You don't want to breath that stuff. Don't weld it, you won't be able to get to anything, if you need to. The sealant that I use is working fine and has caused no problems thus far. I intend on using it in the oven I'm now building and the next one I have in mind.
  #97 (permalink)
Old 06-04-2008, 04:16 PM
GatorHyde's Avatar
Oven done...works great!!!
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
My oven SCHEMATIC...for new oven builders.. RNMHRD Oven Building Forum 39 05-09-2007 05:18 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 10:40 PM
