  #61 (permalink)
Old 01-26-2008, 04:54 PM
GatorHyde's Avatar
GatorHyde is an unknown quantity at this point
Default Re: GatorHyde oven
Welcome TIC1! Got McMaster tadpole oven door seal done and all elements wired and secured to the recess pans. Lights are in and thermocoupler. Waiting on Grainger Induced Draft Fan.
GatorHyde of Denver
10650 Irma Dr. #24
Northglenn, CO 80233
303 280-3056
  #62 (permalink)
Old 01-29-2008, 11:48 AM
TIC1 is on a distinguished road
How does the oven work I am caught between a 4x4x4 and the same one that you built. How is the heatup time? How many amps does yours draw?
Thanks
Pete
  #63 (permalink)
Old 01-29-2008, 01:12 PM
GatorHyde's Avatar
I have yet to fire it up. Waiting on fan. Then to hang door and install glass. I should be able to fire it up within a 2 weeks. I can't find my email from Ken where we discussed amp draw and all that. I know I had to install a 50 amp fuse and my total element watt are (3) @ 3100 watts = 9300 watts....and going by memory amp draw is something like 37.85. Someone may be able to direct you to a program somewhere on this site that calculates element wattage and amp draw.
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
  #64 (permalink)
Old 01-29-2008, 01:22 PM
Thanks for taking the time to answer. you have helped me decide to build the same oven you built. Just waiting for ken to pm me back. Where did you get your fan from and also how are you going to install it? Again thanks.
Pete
  #65 (permalink)
Old 01-29-2008, 01:53 PM
kg4mon is on a distinguished road
I went to mcmaster.com , Which tad pole seal did you get? And a link to the fan would be nice too. Thanks Rick
  #66 (permalink)
Old 01-30-2008, 11:27 AM
GatorHyde's Avatar
Tadpole seal # 8815K41 , 5/8" bulb and 1 3/8" overall. Cut and paste the part number in their search slot.
http://www.mcmaster.com/
Fan was purchased from Grainger, Nothing to powerful...just enough to move hot air from top to bottom.
http://www.grainger.com/Grainger/items/4MH34
Fan install pics...coming soon.
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
  #67 (permalink)
Old 01-30-2008, 02:24 PM
GatorHyde's Avatar
Fan install. First I think I will say that if I was building another oven I would frame 1st, sheet the inside, element/fan/light install, wire, then insulate. Live and learn. With that said, I removed the back sheet metal and insulation to install the fan. Measured, and centered, cut the 5" hole, ground it as "round" as possible and drilled the fan mounting bolt holes. Before permantly installing it I am going to put a bead of RTV high temp seal around the round hole where the fan meets the sheetmetal.
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
  #68 (permalink)
Old 01-30-2008, 02:43 PM
Lookin good. If you don't mind me asking what did you use for the glass. And also where did you get it from?? Thanks
Pete
  #69 (permalink)
Old 01-30-2008, 08:30 PM
GatorHyde's Avatar
I have not bought the glass yet. Another hurdle when I get the door hung.
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
  #70 (permalink)
Old 01-30-2008, 09:39 PM
PhredAre is on a distinguished road
Gator, Look for a donor oven with a glass in the door. I used the glass out of a whirpool stove. There were 3 pieces of tempered Glass, two of which were in a metal frame, with a little fabrication I had a good safe window to view the goings on in the oven. I did use all three pcs. Fred
My oven SCHEMATIC...for new oven builders.. RNMHRD Oven Building Forum 39 05-09-2007 06:18 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 11:40 PM
