  #11 (permalink)
Old 01-25-2008, 10:22 PM
JTW37's Avatar
Caswell Platinum Member
Default Re: pcer Oven Build
You have to look really close on the elements toward the wire end. It is stamped real small. As for the vent, you can put it about anywhere you want, but close to the top. It only needs to be a small pipe, say 5/8 or 3/4. Just so it can vent.
Good to see your coming along with it.
President! no, but thanks for the thought. Just doing what was done for me when I built my first oven. Couldn't have done it without the guys here.
  #12 (permalink)
Old 01-26-2008, 10:55 AM
pcer is on a distinguished road
I stuck a 3/4 copper pipe in the top left side.
It takes about 15mins to get to 400F
I will check the elements sometime....if they are like 1000watts I might get some 2000 watters or somthing.........
NOW TIME TO GET SOME POWDERCOATING DONE!!! hopefully it warms up, no fun working in a unheated shop at 0-32F
  #13 (permalink)
Old 01-27-2008, 10:19 AM
Mickey1031 is on a distinguished road
looking at the photo you have ehre of the finished product.
Looks pretty good .
but have to ask where you found the plans for this whole thing.
I also would like to build a oven for P.C. and have no clue as to where to find plans etc...
Thanks for any help you have on this.
  #14 (permalink)
Old 01-28-2008, 05:51 PM
I really didn't look at plans.....I just read and read on here and used that plus my skill and injeunity in fabricating/nigger rigging
If you are going to build one about the size of mine, I recommend NOT using a refrigerator as the shell, just start from scratch on the frame and build it like gatorhydes frame is. Also, if your oven isnt going to be bigger than mine I would recommend using the parts out of a kitchen oven, its a whole lot less confusing, I still don't understand these fancy wiring diagrams and PID's and all the other stuff.
You can get alot of the stuff at your local Home Depot/ Lowes. Look on craigslist for a used NEWER kitchen oven for $50 or less.
I am actually using this oven the first time right now, its degassing a atv subframe right now, when its done I'll powder coat it candy metallic red!!! pics of the finished product will be up soon
  #15 (permalink)
Old 01-28-2008, 08:18 PM
JTW37's Avatar
Hey pcer,
Got a question for you on your oven. I was looking at your pic of your inside and see where you mounted your fan inside. How did you go about that. I mounted mine on the out side.
  #16 (permalink)
Old 01-28-2008, 10:09 PM
I want pics of your fan setup, I dont understand how you got yours outside.....I basically just cut a square hole in the back and stuck the motor in it.....Its still going
  #17 (permalink)
Old 01-29-2008, 07:27 AM
JTW37's Avatar
I'll see if I can get pics today. Git a bunch of parts to coat today and tomorrow. Maybe a drawing if I can locate it.
  #18 (permalink)
Old 01-31-2008, 09:35 AM
JTW37's Avatar
Made up a drawing how my fan is set up. Photo to follow tonight.
  #19 (permalink)
Old 01-31-2008, 11:29 PM
slowdrive is on a distinguished road
Sorta like this......great info JT thanks you guys are giving me ideas on the fly......
  #20 (permalink)
Old 02-01-2008, 12:21 PM
FigureLLC's Avatar
slowdrive, are you using that blower for an oven? do you know what the rated intake temp is? just something to consider, especially if you're planning to mount it on top of the oven where it will see even more heat. we used a hi-temp version of that kind and mounted it on the back. i think the type jtw37 is using is actually meant for use in forced convection ovens so it should take the heat fine regardless of mounting location.
Len
Figure Engineering, LLC
What will i need to build a oven 8x4x4 Catmando Oven Building Forum 7 07-25-2007 10:50 PM
My oven build misterwelder Oven Building Forum 2 01-15-2007 01:01 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 11:40 PM
i want to build an oven suprtong Powder Coating Questions 4 03-11-2005 02:43 AM
How to build an oven Sezer Oven Building Forum 2 12-24-2003 04:42 PM
