  #21 (permalink)
Old 02-01-2008, 01:16 PM
slowdrive is on a distinguished road
Default Re: pcer Oven Build
Originally Posted by FigureLLC View Post
slowdrive, are you using that blower for an oven? do you know what the rated intake temp is? just something to consider, especially if you're planning to mount it on top of the oven where it will see even more heat. we used a hi-temp version of that kind and mounted it on the back. i think the type jtw37 is using is actually meant for use in forced convection ovens so it should take the heat fine regardless of mounting location.
It is the power vent off of my hot water heater that I just replaced, so it was made for heat.....just to be safe I did look up the specs on it and it is for use on convection ovens also.
  #22 (permalink)
Old 02-04-2008, 07:00 AM
FigureLLC's Avatar
Caswell Platinum Member
nice! giddee-up!
Len
Figure Engineering, LLC
What will i need to build a oven 8x4x4 Catmando Oven Building Forum 7 07-25-2007 10:50 PM
My oven build misterwelder Oven Building Forum 2 01-15-2007 01:01 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 11:40 PM
i want to build an oven suprtong Powder Coating Questions 4 03-11-2005 02:43 AM
How to build an oven Sezer Oven Building Forum 2 12-24-2003 04:42 PM
