Well Im about 75% done so I guess I will post up some pics
![]() http://i30.photobucket.com/albums/c3...m/DSC03153.jpg Remnants of the donor oven: http://i30.photobucket.com/albums/c3...m/DSC03372.jpg I stripped out all the plastic/rubber/sheetmetal/INJECTED INSULATION<<<hardest part Heres a pic of the door installed ![]() http://i30.photobucket.com/albums/c3...m/DSC03378.jpg Im going to paint the whole thing silver on the outside, its not too pretty now. http://i30.photobucket.com/albums/c3...m/DSC03379.jpg Today (Christmas day) I insulated and sheetmetaled the door, tore apart the donor oven and tagged all the wiring, and insulated and sheetmetaled the floor. whew cant wait to try it out. |
got the control panel mounted on top, and the back piece of sheetmetal marked and notched, gotta get it bent.
Now, what has everyone else used for a circulation fan ![]() im thing this: http://www.grainger.com/Grainger/items/5E651 for latches. |
Appears that you got things under control. Oven looks like it is about done. I've tied a couple of different fans. This is a link to the one I'm currently using. There are other styles. This one runs $7.95 + s&h. Take a look. A convection oven fan has been used as well. Good luck. JT
http://www.surpluscenter.com/item.as...tname=electric
Who says you can't teach an ole dog new tricks? |
ok ordered your fan hope it works. also got these latches ordered:
https://www.surpluscenter.com/item.a...item=14-1111-B cheaper than grainger!!! |
welp i fired her up last night........
![]() She wouldn't get any hotter than 300F......but at least It IS well insulated, according to my sweet little laser thermometer the hottest it got on the ouside was 80F around the door seal, the rest of it was around 30F (air temp was 24F) I got a nice little circulation fan wired to the oven light, so I got air movement. I DON'T have a vent yet...... I couldn't get both of the burners on at the same time Im think maybe I should wire them together so they are both on and it would heat to 400F? My dimensions are 22"x30"x60" I'm running on a 220v 30amp circuit and can't afford to get a bigger circuit. What is the max wattage of an element can I get with this circuit? Last edited by pcer; 01-24-2008 at 12:52 PM. |
JTW37 For President 2008!!!!!!
wired the elements together, It heated up to 400 within half an hour (I am timing it right now to see exactly how long it takes) I can't find the watts stamped on the elements, where should I look? Also, where do you all think I should install the vent? thanks alot! Here is a link to the pics of the build http://s30.photobucket.com/albums/c3...Powdercoating/
| What will i need to build a oven 8x4x4 | Catmando | Oven Building Forum | 7 | 07-25-2007 10:50 PM |
| My oven build | misterwelder | Oven Building Forum | 2 | 01-15-2007 01:01 PM |
| Good oven shell for wanting to build your own oven | dannydone | Powder Coating Questions | 6 | 03-21-2006 11:40 PM |
| i want to build an oven | suprtong | Powder Coating Questions | 4 | 03-11-2005 02:43 AM |
| How to build an oven | Sezer | Oven Building Forum | 2 | 12-24-2003 04:42 PM |
