Old 01-01-2008, 12:18 PM
GatorHyde's Avatar
GatorHyde is an unknown quantity at this point
Default Blast cabinet on the way!!!
Realizing I need a blast cabinet, I counted my pennies and bought the best one I could afford. Is it the best cabinet...probably not, but it will get me going and was discounted a $100.00 off from Harbor Freight.
Cabinet details:
Dual side doors for long objects with a large front door for bulky items. Includes brass flow valve, two nozzles, air regulator, large particle separating screen and easy access clean out door.
  • Sturdy welded steel construction
  • Rust resistant powder coat finish
  • Extra bright, twin tube 18 watt fluorescent light
  • Foot operated activation switch
  • 25'' long reach rubber gloves
  • Dust reclaimer outlet (dust reclaimer sold separately)
Nozzle sizes: 6 mm and 7 mm; Abrasive capacity: 15 lbs., Door opening dimensions: 19-3/4" W x 19-1/4" H (x2 side), 46" W x 13-11/16" H (front); Working area: 47-3/4" W x 24" D x 22-1/2" H; Viewing window dimensions: 22-1/2" W x 10-1/2" H, Air requirements: 50 to 125 PSI @ 12 CFM; Air inlet: 3/8"-18 NPT, Overall dimensions: 51" W x 36" D x 65-3/4" H, Shipping weight: 297 lbs.
GatorHyde of Denver
10650 Irma Dr. #24
Northglenn, CO 80233
303 280-3056
Old 01-01-2008, 11:47 PM
TrailLogic is on a distinguished road
Default Re: Blast cabinet on the way!!!
Hey, glad you posted this up!! I am about to buy that same cabinet, how/where did you get the 100 bucks off?
Old 01-02-2008, 09:04 AM
pcer is on a distinguished road
nice setup man.............when i get my oven done (hopefully by sunday) i will be picking up a blast cabinet from a neighbor for $100.
Old 01-02-2008, 02:54 PM
jabe421 is on a distinguished road
No....... Don't buy it yet!
Before you buy check out http://www.harborfreightusa.com/html...on/coupon.html
It will save you 15%, so 15% of $600 will put another $90 in your pocket. This coupon is for in store only and not all stores have the blast cabinets but the one I go to in Michigan sometimes has them, they will also order them.
Good luck!
Old 01-02-2008, 03:51 PM
you had me going for a second, the coupon is only good for in store items. This cabinet is specialorder only.
Thanks anyway.
Old 01-03-2008, 08:56 AM
GatorHyde's Avatar
The cab is sold everyday at $699.00 and it is now being offered at $599.00 ...that's your 15% right there...a little more actually. The delivery charge was $66 and change, delivered right to my shop. And seeing how the shipping weight is 297 lbs and I paid NO tax...they can bring it to me for that price!
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
Old 01-09-2008, 10:41 AM
GatorHyde's Avatar
Blast Cab arrived yesterday, well packed and all the pieces there. Took about 1 1/2 hours yo put it together. Cleaning the shop organizing, gotta build a small platform to replace the temporary bucket lift for the 30" lil oven, LOL. Making progress.
Alex
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
  #8 (permalink)
Old 01-09-2008, 11:30 AM
nuttyman's Avatar
nuttyman
I have the same cabinet. The nozzles are special order only as well & take approx. 2 months to arrive. order some right away if you are planning on using the cabinet often. Did you get the dust collector made for this cabinet too? the legs wobble like hell & if you put casters in the pre-drilled holes they will wobble even more. Weld some braces to the legs as support; it will prevent the wobbling. Also install a moisture trap just before the regulator. they gave me $100 off too because it was on back order for 3 months when I first bought it last year.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
  #9 (permalink)
Old 01-09-2008, 12:02 PM
GatorHyde's Avatar
I have a moisture trap ready to install right where it goes into the cab. Yes got the dust collector too. I have a Miller 180 Mig and will weld at will when the wobbling starts!!! Thanks for the tip.
GatorHyde of Denver
10650 Irma Dr. #24
303 280-3056
  #10 (permalink)
Old 01-09-2008, 12:28 PM
nuttyman's Avatar
nuttyman
feed it with @least a 1/2" diameter pipe/hose too or you won't have enough volume. what size. comp. do you have?
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
dust collector on blast cabinet? shamrox Powder Coating Questions 13 06-05-2008 11:21 PM
road to a new blast cabinet krymis Other Metal Finishing Questions 6 09-11-2007 01:15 AM
How's the TP tool's 770 (skat) blast cabinet sal1355 Other Metal Finishing Questions 0 12-31-2006 03:28 PM
Incandesent lighing in blast cabinet ottoplex Powder Coating Questions 1 09-10-2006 10:05 PM
building a blast cabinet from scratch 11111111 Powder Coating Questions 10 05-11-2004 04:59 PM
