![]() I'm almost finished cleaning out all of the factory foam insulation in this upright freezer that I'm wanting to turn into a PC oven. I wanted to get some opinions on my plans for finishing this project. First of all, I was thinking that instead of lining the interior of the freezer with high temp insulation and sheet metal, I would line the exterior of the freezer and encase the entire thing in hardi backer board.... My plan was to gain that extra space and not have to deal with pop riveting the interior. from there I've got the whole wireing harness, two elements and control panel from an electric range that I'll be using to heat the oven. Still unsure If a fan will be necessary? also unsure about how to secure and seal the door. I'd appreciate any store links, plans, tips, anything that would aid in me completing this project and it work safely. thanks, |
hello there,
if you have followed my thread started sometime ago on my freezer oven donor then you will of read up on some of the perils that are associated with these items especially the foam, apart from the main pain in the butt getting the foam out, once removing it it causes the walls etc to lose some of its rigidy, as i found out almost to my cost due to my friends heavy feet There are almost hints and tips on every thread posted to help us with our oven making,but i am still 'Electric dumb' so it will be trial and error when i get my donor elements etc fitted. please strip one section at a time and then fit the sheet, or at least secure all corner points or the frame will become very weak. keep us posted, with pics if possible. regards, grommit UK |
Thanks for the replies.
Also, would any fiberglass tadpole seal work, specifically the cheapest one listed at $1.80 ft.? Or should it be alittle larger? thanks |
| upright freezer to oven project help please | grommit | Oven Building Forum | 0 | 09-30-2007 05:38 AM |
| Chest Freezer into curing oven | tboard | Oven Building Forum | 4 | 07-10-2006 11:45 PM |
| Coating stuff to go in a freezer | UnorthodoxCreations | Powder Coating Questions | 6 | 05-23-2006 10:22 PM |
| Would using a stainless steel freezer body for a PC oven be | bar_acres | Powder Coating Questions | 4 | 11-04-2004 07:17 AM |
