I stepped on a Gator's tail, tick him off a little. I'm new to this form stuff and find a great wealth of knowledge on these sites. I'm thinking of building my own oven for curing ceramic coatings. Any one have any info.
Guns-out |
The principle is the same as PC ovens. The same controller and heaters will work too. What you'll need is better insulation as most of fiberglass insulation is rated 1000 degrees or less. You'll need to move into the mineral wool or ceramic type insulation for higher temperatures. It costs more but it's still cheaper than fire brick.
Some of the cure temps for ceramic coatings get into the 1500-1700 degree range and some are half that. The type of coating you intend to use should guide your selection for insulation. Also, higher temp ovens are extremely hazardous so you'll have to consider vent design and possibly safety locks on the door. Wood products will burst into flames immediately if exposed to these higher vent temperatures. Above 1000 degrees, you're in the oxidation stage of steel and it will begin to glow dark red. Your liner may need to be ceramic coated or layered with a kiln material to extend life. |
You didn't tick me off, you just posted within a thread asking a question that had nothing to do with the thread, and limited yourself to exposure. Here is a link for Mineral wool. Email them they will tell you the closest distributor:
http://www.roxul.com/sw34066.asp
GatorHyde of Denver 10650 Irma Dr. #24 Northglenn, CO 80233 303 280-3056 |
Thanks guys for the info. I'm a gun bunny by trade and mostly worked with GunKote, Duracoat and some special gear coats for aotomatic firearms. I've recently took intrest in powder coating and ceramic coat. This is due to the amount of request I've received in the last six months by the car and sled buffs.
Once again. Thanks. Guns-out |
| started building my oven | defed | Oven Building Forum | 76 | 05-18-2008 12:25 PM |
| building oven | sawman | Oven Building Forum | 4 | 09-10-2007 05:57 AM |
| Building oven question? | Deecoat | Powder Coating Questions | 14 | 04-23-2006 04:17 PM |
| Oven Building | hd-ryder | Oven Building Forum | 0 | 04-16-2004 10:52 AM |
| Yet another Oven Building question. | tomg552001 | Oven Building Forum | 1 | 08-23-2003 11:42 PM |
