Old 01-20-2008, 09:36 PM
Crimson
Default SSR question
If I am using the following SSR and the following wiring diagram what wires go to what numbers on the SSR??
Thx Mike
Old 01-20-2008, 11:48 PM
PhredAre is on a distinguished road
Default Re: SSR question
If your PID terminals 6&7 are DC they should have polarity on them of positive(T) and negative(-), just match the polarity up to the SSR terminals 3&4, that will take care of the control circuit. The line/load side of the SSR are on terminals 1&2 . This is a single phase switch. If you look at the wiring diagram , on the left side of the contactor drawn on the diagram are 2 terminals with a 10 gage line side, and a 10 gage load side terminal. These two terminals represent terminals 1&2 on your SSR. Simple enough.. just remember to open the panel feeder bkr or unplug the oven before doing any work on the elements because they will aways have at least 110 volts on them. Fred
Old 01-21-2008, 09:23 AM
Crimson
After looking at the wiring diagram again and this pic of the back of hte PID are 1&2 on the PID wiring diagram not backwards??
Old 01-21-2008, 10:55 AM
ed_denu is on a distinguished road
Mike, That's my wiring diagram you're looking at. The PID I'm using (TC408) is not polarity sensitive on the inputs(1 & 2). If your PID is, then adjust the wiring to match polarity. Ed
Old 01-21-2008, 11:03 AM
Crimson
ok thx Ed, Just wante to make sure I was reading it right
Old 01-22-2008, 04:15 PM
rowdenboyz is on a distinguished road
Make sure you use a heatsink for the SSR. I found out the hard way! CURPOW! Those things get aweful hot with out the sink.
Old 01-22-2008, 06:35 PM
Crimson
Yea I already have a heatsink setup for the SSR
  #8 (permalink)
Old 01-24-2008, 11:08 AM
peter61 is on a distinguished road
What is heat sink and where can you get it?
  #9 (permalink)
Old 01-24-2008, 02:27 PM
Crimson
  #10 (permalink)
Old 01-24-2008, 10:15 PM
What does the resiter symbol mean on the wiring diagram?Do you need to install a resister to connect legs 8 and 9?
