Old 01-22-2008, 09:12 PM
eshine is an unknown quantity at this point
Default 3000W Element enough?
I am just about done my 3x3x3 oven. It is 2x2 tubing welded with 16 gauge inside skin and 18 gauge outside skin. I insulated with Roxul insulation. My question is will a 3000 element be enough? I Can run up to a 3500W element but anything over 3000W was hard to find. According to the calculator in the sticky if I rate my insulation as GOOD I would only need 2400W to raise to 425F but if I rate the insulation as Average I need 4800W. Any idea if I am wasting my time trying this 3000W element? Thanks.
Old 01-22-2008, 09:31 PM
JTW37's Avatar
Caswell Platinum Member
Default Re: 3000W Element enough?
First off, I wanted as much heat as I could get in my oven, so I wouldn't take very long to ramp it up from room temp. If you have a high enough amp circuit breaker (50) and at least a 100 amp service then you could run three 3000 watt'ers and get it up to temp in about 8 min. They would pull 37.5 amps.
But then I don't know where you want to be or go with it.
UR turn.
Old 01-23-2008, 08:04 AM
UR turn.
I am fine if it takes 15 minutes to get to temperature.
Old 01-23-2008, 09:28 AM
ed_denu is on a distinguished road
3000 watts will probably take a minimum of 30 minutes or more to heat up to 400. My oven is the same cu ft (27) and with 5200 watts it take mine around 25 minutes to heat up, especially now in the winter time. I would look to add multiple elements if you have the electrical service to support it.
Old 01-23-2008, 12:25 PM
baz baz is offline
baz will become famous soon enough
i also think you should have more ,
i don t think that calculator is very accurate . my smaller oven has about 9000 watts and takes around 12 minutes to heat up .
also your inner walls being 16 gauge it will take longer then some other home made ovens that use 18 or 20 gauge steel. you have more mass to heat up and takes more time for heat to sink in 16 gauge steel , however being thicker once its heated up when you open the door to put parts in the oven should reheat faster because ovens with a thicker gauge stay hot longer
baz
http://www.polissagepb.com
Old 01-24-2008, 12:02 PM
I ended up going with two 2000W Elements in Parrallel, better than 3000W, hope it goes well.
Element Connectors? donafams Oven Building Forum 4 12-03-2007 05:06 PM
Wiring for a three element oven?Element Help pappahenn Oven Building Forum 10 11-06-2007 08:32 PM
2 Element Oven TiE_Shepherd Oven Building Forum 4 10-11-2006 12:13 AM
adding an element ironrose Oven Building Forum 2 09-12-2006 04:25 PM
type of element baz Oven Building Forum 5 07-10-2006 07:43 PM
