I have been reading for a while and there is alot of info on here. I am looking to build an oven that is 4ft wide x 4ft high x 6ft deep. I am new at this and am looking for a little guidance. I plan on using electric heat. I am wondering on element placement and if I need a fan, where to put it.
Thanks Pete |
I read back over your post and realized that your building your oven laying down instead of up right. What's your idea behind that? What do you figure you will be coating?
As for placement of the elements in that configuration, I would plan on them in the bottom. I all depends where your putting your door, top or front. You can find out what BTU's you will produce by looking on this web site ( http://www.heatershop.com/btu_calculator.htm ). It will ask you for "Fahrenheit temperature increase" I put in 400 and then put in your oven size and total watts. It will tell you roughly what the BTU will be. Have a peek at mine. I used what I had laying around for the frame 2X2 square tube. Tried to make it as versatile as I could, 3X3X6. Should have built it 4X4 instead. http://s80.photobucket.com/albums/j1...20Coat%20Oven/
Who says you can't teach an ole dog new tricks? |
I changed the size to 4x4x4. I think the 6 ft is a little big for now. Maybe later tho. Your oven is looking good.I want to get started on mine asap. Should I need a fan??
Thanks Pete Last edited by TIC1; 01-28-2008 at 09:56 PM. |
i think 2 elemets will work but it will take longer to get to temp , if you intend on doing thick (dense) metals it will be even worse . if your power supply can handle it you should put more elements in and a fan is not a must but it will help to get rid of cold spots in there
| gas oven questions | zackjames212 | Oven Building Forum | 0 | 12-29-2007 02:56 PM |
| oven questions | Gyrocopter1 | Oven Building Forum | 5 | 01-30-2007 10:43 AM |
| oven questions | Gyrocopter1 | Oven Building Forum | 0 | 01-15-2007 09:46 PM |
| More oven questions.....? | wamontgomery | Oven Building Forum | 0 | 03-26-2006 07:42 AM |
| oven questions | tavo1765 | Powder Coating Questions | 2 | 03-03-2005 09:30 PM |
