When I pushed the set button I got PASS on the top PV read out and 000.0 on the bottom SV read out,with the 1st 0 flashing.I can change the numbers up and down but my oven will not fire up,any ideas?Thanks. Peter |
A little more information would be helpful.
What controller are you using and where did you purchase it? Are you able to set any of the PID parameters or temperature and alarm set points? Have you attempted to allow the auto tune function of work? |
The controller model # is TET612 I purchaced it from E-bay,the site where alot of members here buy(I forget the name of it)I can put in numbers in the SV screen but the PV screen still has the EEEE'SI have taken controller out of the box.brought it inside,hook up voltage and a new thermocoupling and still had the same results, EEEEE,what gets me is the PASS I get when I touch the set button.
The EEE.E is an out of range indication on the process value, is the TC polarity correct? On my PID the only time that the set button is used is to change the operating parameters of the PID. Out of the box, I only needed to use the up button to raise the set value, and the down button to decrease the set value. Actually it takes two pushes of the up or down button to make the desired set temp change. Do you have the PID instructions? If not ,they are here;http://perfectplanes.com/TET612_Inst...nal_manual.htm I'm sure Ed will be able to help you,I"m thinking he has the same PID. Fred
JEEZ... I'm going to have to learn to type faster... Last edited by PhredAre; 01-26-2008 at 11:46 PM. |
| Dumb question of the day: Read here | Cub | Metal Polishing Questions | 18 | 02-28-2007 11:29 AM |
| Strange problem ,all of a sudden? | MrPontiac | Electroplating Questions | 3 | 11-23-2006 11:22 AM |
| strange finish | acidcustom | Anodizing Questions | 2 | 06-12-2006 12:05 AM |
| Before Asking For Plating Help, Please Read This | mcaswell | Electroplating Questions | 0 | 11-18-2005 02:14 PM |
| Strange apperance | PeterM | Anodizing Questions | 8 | 03-10-2004 11:45 AM |
