Old 02-12-2008, 05:26 PM
Crimson
Default Oven Help??
So my oven was working ok until the wire that was in my garage for my welding plug failed.. Was in the garage when I bought the house, the wire was not up to rating for the 35+ amp draw of hte oven.
So that has been change now but the oven is not working now! The PID is just reading EEEE now. The PID I have is a TET612
I am using the following wiring diagram with 3 elements not the 2 in the diagram.
Old 02-12-2008, 08:29 PM
ed_denu is on a distinguished road
Default Re: Oven Help??
The eeee is an out of range indication I believe. If the oven was working correctly before the circuit failure, then go thru the setup procedure again for the pid and see if it doesn't start working again.
Also check to see if the correct input type thermocoupler is specified.
If you have a 35 amp draw on the oven I'm presuming you upgraded the wiring to a 50 circuit?
Old 02-12-2008, 09:52 PM
Crimson
What wire are you asking if I upgraded?
I have a feeling that k thermocouple failed. How would I go about testing it?? Can I replace it with a resistor? if yes what value resister?
Old 02-13-2008, 01:52 PM
No, a resistor will not work. Testing was recently discussed in this thread:
Is there a way to test a thermocouple?
The question I was asking about your wiring was the garage circuit that you said failed. Has it been upgraded to support the oven load requirements.
Old 02-13-2008, 07:03 PM
Crimson
yes sorry that wire has been upgraded to support the draw of the oven.
Looking For A Cheap But Good Oven Builder In Eastern Ohio Or A Used Oven 4sale Cheap! REVS Oven Building Forum 3 01-05-2008 12:54 AM
Anyone With A Used Oven Or Can Build A Oven For Me, Ohio REVS Oven Building Forum 2 01-04-2008 11:15 AM
My oven SCHEMATIC...for new oven builders.. RNMHRD Oven Building Forum 39 05-09-2007 05:18 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 10:40 PM
