Well guys I've had a lot of requests for powdercoating parts which where far to large to fit into a kitchen oven so it's time for me to build one. After getting some measurements of many of the parts requested I figure an oven measuring the common 3'x3'x6' ID will do most rear ends, bike frames, suspension parts, etc...
Construction will be the usual Metal stud framing with sheet metal siding. I'll build it in panels so that if I need to move it or transport it later and am in a pinch I can disassemble the oven to move it. To help with warm up times I'll be using a thinner sheet metal on the ID so there is less mass that needs heating. I've decided not to use some of the alternative wall materials mentioned in the past because of the long heat up times they cause. The oven will incorporate an externally mounted convection fan with internal ducting, lights, timer, circuit breaker, and an amp meter. Temp controller will be a 1/16 PID using K type thermocouple and SSR output. I already have some controller boxes sitting around I acquired from a previous job and will either be using one of the computer CPU heatsinks or amplifier heat sinks I have to take care of the heat. I haven't quite decided on the door type yet. I'll probably make it two door so that it requires less space to open. In the top will be a roll out rack supported by two industrial rollers (like for keyboards but bigger). I think they have a 200-300 lb capacity for each and are all stainless steel construction so they'll handle the oven and anything I hang in there just fine. I would like to have 9,000 watts but will probably end up running 6,000 for the mean time since I'm renting a house and probably won't have my own place with a garage for another year. More than likely I'll build the oven with two 3,000 watt elements with everything in place to add a third one later. Below is the list of components with links I'm planning on so far: Temp Controller: http://auberins.com/index.php?main_p...&products_id=3 Solid State Relay: http://auberins.com/index.php?main_p...products_id=29 Thermocouple: http://auberins.com/index.php?main_p...&products_id=2 Convection Fan: http://www.surpluscenter.com/item.as...tname=electric Timer: http://www.surpluscenter.com/item.as...tname=electric Caster Wheels: http://www.surpluscenter.com/item.as...catname=wheels What do you guys think? |
i also have the same concern i have about the same dimensions with 11000 watts , my heat up time is between 23 to 26 minutes but when doing parts with heavy steel plates it takes much longer to get them to temp
Skip that fan for recirculation. It's ok for a vent fan but won't take extended heat cycles because the housing isn't completely closed and the fan drive is made of rubber. I tried these and have since pulled the one I had as a recirc.
The PID comes with a TC so unless you need the extra length of the one you posted, you can skip it too. The timer? Well, unless you're going to use it to make coffee I see no need for this type in an oven. It turns on at a specified time of day so I'm confused about why you included it. Add a heat sink to your list! |
Does Auberins sell all their temp controllers with a TC? Only thing that I saw was that it was configured to use a K type out of the box. Does anyone have other recommendations for a recirculation fan? Basically I want something I can mount to the side of the wall but still be able to run the duct work inside the oven. Since wiring a dedicated circuit for the oven in the house I'll be renting may not be possable I might try making a slide in divider plate to basically cut the size of the oven in half when doing smaller parts. |
but i agree about the timer , its useless for this application the thermocouple on that list has a 1/2 inch threaded probe at the end i think it would be better to use a 3 or 6 inch probe , i bought the 6ft cable with 6 inch probe |
Oh, forgot to mention, the timer was to have a clock close by and would be wired into a buzzer since I'm a very forgetful person.
What would be the benefit of the larger probe? I was thinking smaller would be better since it would react faster to sudden heat changes and would be less likely to get in the way of something in the oven. |
Ok, I guess I misunderstood this info from the website to mean it came with sensor. I got mine off ebay and they came with the TC. Shipping configuration: Input sensor: K type thermocouple (Max working range 32-2300 °F). Display Unit: Fahrenheit (°F) Display resolution: 1 degree. Alarm 1: Deviation low Alarm 2: Deviation high As far as having an alarm clock, if you're away from the oven, what good is it? You'd be better off getting a timer that will shut down the system after the cycle is over. That's what mine does. The control system can also be set to open a vent (or not), to start a purge fan (or not), to restart with a new time or the same time (or not) and to sound an alarm (or not). But, everybody works in a different process environment so I guess it may work if you think that's what you need. Quote:
By making a divider panel that will adjust to the size of your work, you can control the size of the oven as well as which heaters will be used. No sense burning 9000w if you're baking a tin cup. Your only problem will be how to move or locate the TC if you're not using multiples. (Not hard if one end or area is always in use.) |
| my other oven project pics. | grommit | Oven Building Forum | 5 | 10-08-2007 04:04 AM |
| upright freezer to oven project help please | grommit | Oven Building Forum | 0 | 09-30-2007 05:38 AM |
| my first project. | grommit | Powder Coating Questions | 6 | 02-15-2007 09:35 AM |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 32 | 02-28-2005 06:35 PM |
| my first project, | Carcher7878 | Powder Coating Questions | 4 | 04-23-2004 04:21 PM |
