Old 02-18-2008, 09:33 PM
JTW37's Avatar
Caswell Platinum Member
Default Building my second oven - slowly
I've been slowly building a down sized oven, from my first one. Going slow with it. No particular reason, just in no BIG hurry. But I do small parts a lot and figured it would be easier and quicker to do the small things in.
Anyway, at the suggestion of my Son, we are trying out a different approuch to the door. You can check it out with the link I provided. It's a bit dark.
http://s80.photobucket.com/albums/j1...t=000_0002.flv
Old 02-18-2008, 09:59 PM
slowdrive is on a distinguished road
Default Re: Building my second oven - slowly
My luck I would forget to not stand in front of it and wind up picking my teeth out of the ceiling
Looks good.
Old 02-18-2008, 10:20 PM
baz baz is offline
baz will become famous soon enough
cool,any particuar reason for having the door open that way?
that could be useful for customers that try to get their nose too close to my stuff
baz
http://www.polissagepb.com
Old 02-19-2008, 08:28 PM
BottleFed70 is on a distinguished road
Pretty cool!
Will it still open with the added weight of the sheetmetal, insulation, etc?
Also, that gas cylinder is not going to like getting hot and will actually explode if it gets too hot. Whatever you do, design it so that the cylinder doesn't get heated by the oven.
Old 02-19-2008, 10:00 PM
JTW37's Avatar
As for any particular reason? Not really, just trying something different. It does help with it not swinging out, although I had designed it to be two small doors swinging open.
The weight of the door was considered with the purchase of the pistons. I won't have anything in the door other then the insulation, sheeting and a window. Maybe a small door for IR thermo reading. As for getting too hot, they should be okay, as there is air space between the surface and them and they have high impact plastic ends attaching them. But we shall see, won't we? But it should be okay.
started building my oven defed Oven Building Forum 76 05-18-2008 12:25 PM
Learning about electrics....slowly! grommit Oven Building Forum 3 01-16-2008 09:35 PM
Oven Building suppliers jcrossi Oven Building Forum 3 01-15-2008 04:27 PM
building oven sawman Oven Building Forum 4 09-10-2007 05:57 AM
Oven Building hd-ryder Oven Building Forum 0 04-16-2004 10:52 AM
