Yes it's a vent. Without the oven took quite a bit longer to heat up.....we also figured that anytime there's heat there's expansion and the vent would help with that....it's just some threaded pipe and fittings with a shut off valve...all purchased from Lowes.
Here's the rack we made....simple but effective....I'm right around 200lbs and it holds me doing a chin up.
http://i253.photobucket.com/albums/h...photo/RACK.jpg |
I usually leave it about half way open. I'm installing the fan tomorrow...i'll post pics when it's done.
I had a couple of requests for engine blocks.....the only way I could think of getting them in and out of an oven was to not have a floor. |
nice job on the oven, the heat up time is quick,i am still building mine, were did you get your high temp wire and wire clips for the elements from. no window ,how are you checking your flow out of the coating.
The wire came from the same place we got the elements from..the local appliance supply shop. The clips we used to hold the elements down are nothing more than galvanized 1/2 in clamps for securing conduit and othe half inch pipe. We thought about a window but really isn't a need.....If the oven is built right the powder is going to flow right....if it doesn't flow properly there really isn't anything you can do....it's going to have to be blasted again regardless.....atleast that's what we were thinking. I also think if there were a window I would spend all of my time staring at the parts instead of preparing to spray the next part.
| Looking For A Cheap But Good Oven Builder In Eastern Ohio Or A Used Oven 4sale Cheap! | REVS | Oven Building Forum | 3 | 01-05-2008 01:54 AM |
| Anyone With A Used Oven Or Can Build A Oven For Me, Ohio | REVS | Oven Building Forum | 2 | 01-04-2008 12:15 PM |
| My oven SCHEMATIC...for new oven builders.. | RNMHRD | Oven Building Forum | 39 | 05-09-2007 06:18 PM |
| Good oven shell for wanting to build your own oven | dannydone | Powder Coating Questions | 6 | 03-21-2006 11:40 PM |
