  #21 (permalink)
Old 02-23-2008, 09:15 AM
holeshot87
Default Re: New Oven
i have the same size oven. the rack u made would of been cheaper made out of square tubing. still ur came out nice.
  #22 (permalink)
Old 02-23-2008, 10:32 AM
corecase is on a distinguished road
We were going to go that route but we didn't have the welder available to us and the closest place ti us to get the square tubing was almost 45 minutes away.....so this was a cheap and easy alternative......something anyone can put together without alot of tools.
  #23 (permalink)
Old 02-23-2008, 10:39 AM
Our control box was simply the same sheet metal the oven was made from, the definite purpose contactor and an old oven thermostat....very simple yet very effective. Our goal was to build a simple relatively inexpensive oven that would last a very long time. We put our elements in metal outlet receptacles so they would be easy to change and also made sure we used nothing exotic so everything could be purchased cheaply and from the local appliance parts store. We thought about the digital control box but this works just as well and the total cost was around $60.
  #24 (permalink)
Old 02-23-2008, 12:50 PM
TIC1 is on a distinguished road
Where did you get your contactor and how big is it and also what voltage is the coil. Also your timer what kind is it.
Thanks
  #25 (permalink)
Old 02-23-2008, 05:49 PM
The coil is a two pole, 120v, 55amp definate purpose contactor purchased at the same appliance parts supplier as the elements. The one we used costed between 50 and 60 dollars. The appliance supplier will ask for the model number for your appliance but just tell them to give you cheap two pole coil to step up your voltage to 240. The timer is just a cheap digital kitchen timer that uses a AA battery available just about everywhere.
  #26 (permalink)
Old 02-23-2008, 09:33 PM
JTW37's Avatar
Caswell Platinum Member
Here is the contacter I used in my oven when I built it. It sounds similar to one corecase used.
$34.23
C25BNF240A Contactor, 40 Amps, 2 Poles, 120 Coil Voltage
http://www.famousparts.com/c25bnf240aco.html
  #27 (permalink)
Old 02-23-2008, 10:01 PM
Ours was a little fancier only because that's all they had...but that one would work great!....
Looking For A Cheap But Good Oven Builder In Eastern Ohio Or A Used Oven 4sale Cheap! REVS Oven Building Forum 3 01-05-2008 12:54 AM
Anyone With A Used Oven Or Can Build A Oven For Me, Ohio REVS Oven Building Forum 2 01-04-2008 11:15 AM
My oven SCHEMATIC...for new oven builders.. RNMHRD Oven Building Forum 39 05-09-2007 05:18 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 10:40 PM
