Old 02-22-2008, 12:02 PM
corecase is on a distinguished road
Default New Oven
We just finished our new oven. It heats up in 15 minutes. we have a convection oven fan to install this week. We chose to not put a bottom on it so we can wheel an engine stand in and out. The dimensions are 4x4x6. Thanks for all of the help on this forum.
http://s253.photobucket.com/albums/hh53/corecase_photo/
Old 02-22-2008, 01:34 PM
ed_denu is on a distinguished road
Default Re: New Oven
Nice work. How much wattage are you using?
Old 02-22-2008, 02:32 PM
Lightbulb Re: New Oven
Nice Job!
I would suggest you lay thin insualtion and a sheet of tin over the concrete though. There's lots of water in concrete and heating it to temeratures of around 400 is going to produce steam in your oven. Not only that but it could start popping and ruin an otherwise perfect piece. Just a thought.
Old 02-22-2008, 03:51 PM
The oven uses 4 3000 watt elements.
Thanks for the advice on the floor insulation. The concrete has been in place for about 30 years, do you think there is still adequate moisture within it to create steam? There has not been a problem so far but I will keep an eye on it. Thanks.
Old 02-22-2008, 05:18 PM
wetdream is on a distinguished road
Where did you get your heating elements from and the seal for the door?? I'm going to be build the same size in a few weeks.
Old 02-22-2008, 07:06 PM
The heating elements came from a local appliance supply store...Fox Appliance to be exact. The door seal was almost impossible to find by the foot so we just went to lowes and found it in 6 foot sections with the adhesive for around $8 a box. Hope this helps.
Old 02-22-2008, 07:10 PM
We just built our roll around rack today...we used 3/4 in threaded pipe found at Lowes. We put it together with 3/4 in elbows and T fittings....then we put steel casters on it . Total cost was around $80.00. we couldn't find anything close to what we needed for under $200.
  #8 (permalink)
Old 02-22-2008, 07:57 PM
McMaster Carr sells various different door seals by the foot.
  #9 (permalink)
Old 02-22-2008, 08:54 PM
We checked there too....They are really proud of their stuff judging by the prices they are asking.
  #10 (permalink)
Old 02-22-2008, 09:32 PM
More oven pics...our total cost was slightly under $1000...we ran into a slight problem with the contactor. It was 55 amps so we had to run larger wire from the breaker box and install a 60 amp breaker....everything work perfectly now.
http://i253.photobucket.com/albums/h...ecovers001.jpg
http://i253.photobucket.com/albums/h...ecovers006.jpg
Looking For A Cheap But Good Oven Builder In Eastern Ohio Or A Used Oven 4sale Cheap! REVS Oven Building Forum 3 01-05-2008 12:54 AM
Anyone With A Used Oven Or Can Build A Oven For Me, Ohio REVS Oven Building Forum 2 01-04-2008 11:15 AM
My oven SCHEMATIC...for new oven builders.. RNMHRD Oven Building Forum 39 05-09-2007 05:18 PM
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 10:40 PM
