Old 02-25-2008, 12:39 AM
itsallgood is on a distinguished road
Default Ceramic Coating Oven (Thermostat)
I'm building a 2nd oven for Ceramic coatings.
So I need to get pretty hot, higher than a normal household oven will get.
In my previous oven I've used the standard household oven thermostat and it's worked good for me.
However, I can't use it for the new oven because of the max temp setting.
What can I use in it's place, needs to be 120V for my contactor coil, which is probably standard.
Part numbers and prices for the complete setup (thermostat and probe) would be awesome.
Thanks in advance...
Old 02-25-2008, 08:36 AM
ed_denu is on a distinguished road
Default Re: Ceramic Coating Oven (Thermostat)
Most PID controllers can display temperature values into 4 digits and a 'K' thermocoupler can report temperatures to around 2400F. Most if not all PIDs can be configured to operate a 120vac contactor.
Look for these parts at auber instruments or on ebay.
Old 02-25-2008, 06:50 PM
BottleFed70 is on a distinguished road
Like mentioned, go with a PID controller and thermcouple. You can buy these together on Ebay for less than $50.
Old 02-25-2008, 07:32 PM
Yeah, you really can't beat the PIDs for temperature control. They're good for +/- one degree. I'm accumulating PIDs (as fund$ allow) to replace all my plating tank controls and melting pot controls. If I could find some kind of gas control valve with auto ignition, I'd put one on my metal furnace.
Old 02-25-2008, 09:17 PM
So these two things shoudl be all I need...for controlling my contactor 120V Coil 50Amp Contactor.
http://auberins.com/index.php?main_p...products_id=14
http://auberins.com/index.php?main_p...products_id=27
If so, count me in...that's pretty cheap, I should have went that way for my first oven.
Old 02-25-2008, 11:35 PM
Yes sir, that should do it. Well that and a box to make your connections. I noticed the TC probe doesn't look like is has a threaded mount so some sort of high temp grommet may be need to secure the probe. Also note--That probe is good to only 750*F. Don't know what your ceramics are curing at but this may be a problem. Others are available to handle higher temperatures.
Old 02-25-2008, 11:48 PM
Thanks a ton...
I'll make sure to get the higher temp TC.
  #8 (permalink)
Old 02-27-2008, 04:52 AM
JTW37's Avatar
Caswell Platinum Member
As far as curring temps for ceramic, in most cases you don't need to cure them at a very high temp. I cure all the time between 525 - 600. Which is plenty according to the instructions that come with the ceramic.
Ceramic Coating How To? GeneNewcomb Powder Coating Questions 6 11-29-2007 03:46 PM
ceramic coating biz stever Powder Coating Questions 1 11-23-2006 10:54 PM
thermostat question,newly built oven is alive gaskincrew Oven Building Forum 5 05-03-2006 08:09 PM
More Ceramic Coating ?'s callmej75 Powder Coating Questions 10 04-27-2006 02:57 PM
