  #11 (permalink)
Old 03-08-2008, 12:09 AM
wetdream is on a distinguished road
Default Re: WeTDrEaM Oven Build. Step by Step
This is what it looks like after the upright studs were installed and the cross studs were installed. You can see in the pics I have the studs screwed in at the ends. I left room because after the oven is all framed in I am going to go back and drill holes and rivet next to them. After there is 2 fasteners holding each stud the unit will be much more rigid.
wetdream-oven-build-step-step-powder-coating-oven-017.jpg  wetdream-oven-build-step-step-powder-coating-oven-016.jpg
  #12 (permalink)
Old 03-08-2008, 12:11 AM
Here is a pic of the framing with all the cross studs installed. Tomorrow will be the build of the top.
  #13 (permalink)
Old 03-08-2008, 03:49 AM
Fox Fox is offline
Fox is on a distinguished road
Nice going,very pro look to it.Thanks for posting pics.
  #14 (permalink)
Old 03-08-2008, 12:12 PM
Thanks Fox, I'll keep posting pics as I go. Tonight I'll be putting together the top and then framing out the door. Will have pics as soon as I'm done.
  #15 (permalink)
Old 03-08-2008, 01:43 PM
JTW37's Avatar
Caswell Platinum Member
Yep. it looking good. Alot prettier then my was as I was building it. Mine was down right ooogly. But it works good.
Hey Fox, take lots of notes. You'll get'er as well. Just takes time and patients. Oh and Money !
  #16 (permalink)
Old 03-08-2008, 05:19 PM
swpruett is on a distinguished road
Thumbs up Re: WeTDrEaM Oven Build. Step by Step
Looks REALLY good! Nice work. Where did you end up purchasing your 4" Roxul insulation? That is my next purchase and I'd like to avoid having to buy thinner stuff locally and layering to fill the walls.
Thanks!
Pruett
  #17 (permalink)
Old 03-08-2008, 10:44 PM
Fox Fox is offline
Ya i have learned in the past that rushing things only leads to something bad happening so ya i'll keep watch on your guys builds and get the parts for mine over time.
  #18 (permalink)
Old 03-09-2008, 01:54 AM
Here is a pic of the unfinished top installed. I made the framing all the way around and installed the 3 stud flat as you can see. These studs are what the "track" is going to bolt to. I am going to put 1/2" thick X 2" wide flat steel inside these to support weight. The flat steel with be riveted to the studs from the inside. After the sheet metal "skin" is installed I will drill and tap the flat steel so the track can be bolted to it securely. Cross studs will also be installed after the flat steel. I had to leave them out until this is done so I don't cover the "track" studs.
  #19 (permalink)
Old 03-09-2008, 03:00 AM
Here are a few pics of the unfinished door also. Ran out of self tappers!! The lower center square will be where the window is going. I will also be framing below that just like the very top. I decided to add a little more support to it since it is so big. I will also be adding steel stock to the sides where the hinge and latches will attach just like the track. Drilled and tapped so it can be bolted together without worry of the bolts pulling out of the thin studs and sheet metal.
wetdream-oven-build-step-step-powder-coating-oven-019.jpg  wetdream-oven-build-step-step-powder-coating-oven-020.jpg
  #20 (permalink)
Old 03-09-2008, 03:01 AM
Just a few more of how it will look with the door open.
wetdream-oven-build-step-step-powder-coating-oven-021.jpg  wetdream-oven-build-step-step-powder-coating-oven-023.jpg
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 10:40 PM
last step: finishing with wax on gold plating. Which one? didierphmartin Metal Polishing Questions 1 10-29-2004 02:11 AM
Between-step examination? mpierich Metal Polishing Questions 0 09-20-2004 10:43 AM
Step by step fosgate99 Metal Polishing Questions 2 11-08-2002 05:11 PM
FIRST STEP saiyan7 Metal Polishing Questions 7 02-15-2002 08:25 PM
